Hi guys, a little problem saving preferences on 3.13. I change my map colour preferences click apply and then OK. However, when I close down and restart my changes are lost. Am i missing something here?
Cheers in advance.
If you do not save it as default (over write current) but instead give it a different name then each restart you need to reselect it. Easy option is save it as default. If you want to keep the default safe, just load and rename it to something else forehand.
Thanks Dave, I've saved the map with my changes to default by doing the following.
Map > Save Map As > Default > Overwrite
However, when I restart RB again the changes are not there!! I then click
Map > Open Save >Open Map > Default
but the changes still do not appear.
Cheers.
File/Preferences/Map Colours/EXPORT/then pick radar or default. Should work.
Marvelous, thanks Bratters, works a treat!!
