AirNav Radar => AirNav Radar Discussion => Topic started by: RodBearden on June 20, 2010, 01:23:16 AM
Title: Norton problem solution
Post by: RodBearden on June 20, 2010, 01:23:16 AM
I know that this post isn't directly related to RadarBox, but it will give a dramatic boost to its performance on some users' computers. It's to anyone using Norton Internet Security.
I've been plagued by desperate slowing down of my computer for several months, and have suspected a program called ccSvcHst.exe of swamping the processor – it's a Norton scanning program. Today I took the plunge and followed the advice on several forums, and it's worked a treat – it's like getting a new computer! If anyone is suffering similarly, here are the steps – it's very simple, if slightly scary.
1 – make sure you have the Norton Internet Security setup file available. (Mine's called NIS09EN.exe.)
2 – download and run the Norton Removal Tool – available here: http://www.symantec.com/nrt
3 – reinstall Norton Internet Security from your setup file – don't forget to run Liveupdate afterwards.
4 – set Scan exclusions for your RadarBox folder: go to Computer – Settings – Exclusions/Low Risks – Scan Exclusions, then Signature Exclusions
Job done.
I presume this will also work for Norton 360 users – I recommend you check on the Internet first.
Anyone who wants more advice is welcome to PM me.
Title: Re: Norton problem solution
Post by: MIKE.UTD on June 25, 2010, 01:19:06 PM
Hi Rod,
Will give this a go as mines taking 2 minutes to re-boot everytime I switch it on.
Do you set the exclusions for the full airnav system folder as mine is as follows :
C:DRIVE
PROGRAM FILES
AIRNAV SYSTEMS FOLDER
AIRNAV RADARBOX FOLDER
DATA/COLOUR/FOLDERS ETC.
Mike.
Post by: 54901 - Jim on June 25, 2010, 03:53:57 PM
The same advice applies to those using Microsoft Security Essentials ... exclude the ANRB folder from the scans.  Helps a lot!
Jim
Post by: RodBearden on June 25, 2010, 04:18:51 PM
Mike
The only exclusion path I've set is to the main AirNav Systems folder:
C:\Program Files\AirNav Systems
It will exclude all the sub-folders of that folder too.
Hope that helps
Post by: tarbat on June 25, 2010, 04:23:32 PM
Remember that if you're running Vista or Win7, and have Radarbox installed in the default location
C:\Program Files\AirNav Systems\AirNav RadarBox
then you also need to setup a virus scanning exclusion for the equivalent folders in the Virtual Store
C:\Users\xxxxxxxx\AppData\Local\VirtualStore\Program Files\AirNav Systems\AirNav RadarBox
Post by: MIKE.UTD on June 26, 2010, 10:39:35 AM
Did the exclusions for scan and real time no problem just added
Can not add signature exlusions.
Click all brings up long list of virus names or so it appears with add/remove/risk settings, how did you add airnav ??
Or have I done it wrong.
Thanks again for all your help.
Mike.
Post by: RodBearden on June 26, 2010, 11:23:59 AM
Sorry, Mike, I don't think Signature exclusions are relevant here after all. It's the Scan exclusions that matter.
Has what you've done speeded up your system at all?
Post by: MIKE.UTD on June 27, 2010, 09:07:59 PM
Thought as much.
Yes a lot quicker booting up now.
Thanks again and keep up the brilliant work.
Mike.
