AirNav Radar => AirNav Radar Discussion => Topic started by: tarbat on July 06, 2010, 11:13:20 AM
Title: BUG : MyFlights aircraft listed on Network tab
Post by: tarbat on July 06, 2010, 11:13:20 AM
See attached screenshot.   Currently showing all MyFlights aircraft in the Network list, even though "Get Flights from Radarbox Network" is un-ticked.  Probably caused by no operator in the Quick Filter.
Also, what does a status of "Deleted" mean?
(http://farm5.static.flickr.com/4095/4767038643_acb07afd70_b.jpg)
Title: Re: BUG : MyFlights aircraft listed on Network tab
Post by: orkney on July 06, 2010, 11:33:31 AM
Hello Tarbat
We have just tried the same as you and got the number of myflights plus the number of deleted under the network heading add up to make the total in the network tab. This is done with our network switched off also.  Just out of interest what made you think of trying this?  What deleted means I dont know either-it could be an internal command used to tell the programme the flight has timed out and not to display it in the column of myflights any more.
Andrew
Post by: tarbat on July 06, 2010, 12:23:47 PM
Quote from: orkney on July 06, 2010, 11:33:31 AMJust out of interest what made you think of trying this?
An accident.  I'd just started Radarbox, and always setup a quick filter of Distance < 250NM, and forgot to select the "<" from the dropdown list.  Same happens on MyFlights, where I normally setup a quick filter of Latitude = 0.
Post by: Southwest on July 06, 2010, 05:55:58 PM
Not suggesting anything sinister is going on are we?
Post by: AirNav Support on July 06, 2010, 07:41:50 PM
Thanks we have noted this. Though it shouldn't impede on general running of RadarBox.
Deleted flights are simply ones which have timed out, but still in the session data of the database so in case they appear again while still in the deleted state they will stay as one session in the database.
Post by: orkney on July 06, 2010, 07:59:54 PM
Quote from: AirNav Support on July 06, 2010, 07:41:50 PM
Hello
In other words it is just an unintentional "Easter egg"  :-)
Seriously though it doesn't affect things but would this deleted flights not explain the users complaining of the excessive memory usage after leaving the box on for days or are the "deleted" flights fully deleted after a set time?
Andrew
Post by: AirNav Support on July 06, 2010, 08:28:00 PM
No, as the deleted flights are then purged after a certain time.
Post by: orkney on July 06, 2010, 08:30:38 PM
hello
I did think they would have been but was just wondering in case they weren't.
Andrew
