AirNav Radar => AirNav Radar Discussion => Topic started by: bratters on August 09, 2010, 08:25:51 AM
Title: Question for Airnav
Post by: bratters on August 09, 2010, 08:25:51 AM
Regarding the recent discussion about signal distances, what is the maximum range at which the Polar Diagram operates and will register an aircraft please?
Title: Re: Question for Airnav
Post by: airdata on August 09, 2010, 08:33:31 AM
I had radarbox running on a laptop whilst flying toward my home airport recently and the spike appeared at 300nm.  I don't know if that is the system default but that's what happened...
Post by: AirNav Support on August 09, 2010, 08:38:47 AM
Hi Bratters,
Don't know the exact details to the algorithm but we think it has a limit of recording 300nm to which anything after is ignored as being an error.
However the above is educated guess, dev can confirm whats exactly coded.
Post by: orkney on August 09, 2010, 08:52:13 AM
Hello
How about having a polar diagram modifier in the next version to remove single positions so the user can erase spikes. I know you can just start an new polar diagram but it takes a few weeks to build a good one here so would only start again if there was an extreme deformation.
Andrew
Post by: bratters on August 09, 2010, 10:10:51 AM
Quote from: AirNav Support on August 09, 2010, 08:38:47 AM
Hi Bratters,
Attached pic shows a spike at approximately 320nm but as nothing has exceeded that in the last 4 months, I would think that's possibly the maximum.
I'm interested to hear what Dev has to say.
I like Orkney's idea of a "spike-eraser" - very useful.
Post by: tarbat on August 09, 2010, 11:24:10 AM
Quote from: orkney on August 09, 2010, 08:52:13 AMHow about having a polar diagram modifier in the next version to remove single positions so the user can erase spikes.
In the meantime, you can do that manually.  Close Radarbox, and then open the D012.dat file in the DATA folder in Notepad.  You can then reduce any values that are incorrect - there are 360 values, from 0 - 359 degrees.
Post by: bratters on August 09, 2010, 01:04:53 PM
Quote from: tarbat on August 09, 2010, 11:24:10 AM
Brilliant that man!
Post by: NF2G on August 10, 2010, 01:07:55 AM
On a related note, is there a list somewhere that tells what each of the d##.dat files is supposed to contain?
