AirNav Radar => AirNav Radar Discussion => Topic started by: AirNav Development on August 29, 2010, 04:31:26 PM
Title: Flight Number / Call sign Database significantly increased
Post by: AirNav Development on August 29, 2010, 04:31:26 PM
We have today deleted all records without origin/destination from our database forcing it to be totally refreshe during the next 24 hours which should significantly increase the number of org/dest data shown.
Title: Re: Flight Number / Call sign Database significantly increased
Post by: EK01 on August 29, 2010, 05:29:27 PM
AN,
Does that  'all' include origin/destination details for alphanumeric flight numbers ?
Post by: AirNav Development on August 29, 2010, 05:40:37 PM
Yes, for most of them.
Post by: EK01 on August 29, 2010, 05:44:23 PM
Thanks AN. That will be a great improvement.
Post by: tarbat on August 29, 2010, 06:11:20 PM
So, is now an appropriate time to delete all records from our local navdata routes table?
Post by: DaveReid on August 30, 2010, 10:55:00 AM
Quote from: tarbat on August 29, 2010, 06:11:20 PM
Don't be too hasty in deleting your local routes database, I'd hang on for a few days at least.
I don't know if the routes currently being returned by the server are the same as those in AirNav's master routes database (since I don't understand what this "24 hour refresh" process is all about).
Having said that, I've just run a random sample of Heathrow flights against the server.
Of those, 10% are returning routes which are either wrong/out of date (e.g. BAW21P/BA603 LIRP-EGLL) or simply blank (e.g. BAW29CE/BA341 LFMN-EGLL).
Of the incorrect/blank routes, 75% are alphanumeric flight numbers.
As I said, I don't fully understand the update architecture, so it's possible that over the next few days the refresh process will populate all those alphanumerics.
I'll run another test in a few days time.
Post by: knight01 on August 31, 2010, 08:31:36 AM
I'm still getting incorrect routes from the server.  If I delete or modify the incorrect route, the server just updates it again with the incorrect version.
example: I just noticed VIR22F is EGLL > KIAD in database, so I change it to the correct routing KIAD > EGLL.  But as soon as I restart the application, its back to the incorrect route.
Another example: Air Transat TSC134 CYQB > MMUN in database.
Correct routing CYYZ > EGKK and its on approach to Gatwick.
This has happened multiple times with multiple airlines/routes and its getting really frustrating.  The server keeps modifying routes I've added manually with the incorrect versions.
Now I'm wondering how many routes in the database are actually correct.
Post by: DaveReid on August 31, 2010, 08:53:56 AM
Quote from: knight01 on August 31, 2010, 08:31:36 AMThis has happened multiple times with multiple airlines/routes and its getting really frustrating.  The server keeps modifying routes I've added manually with the incorrect versions.
Have you tried populating the CH field for the record in question with a current date/timestamp ?  My understanding (though I could be wrong) is that doing this will prevent newly-edited routes from being overwritten by data from the server that's out-of-date or, as in this case, simply incorrect (I do a lot of work for Virgin in my day job and I know for a fact that eastbound flight numbers are even and westbounds are odd).
QuoteNow I'm wondering how many routes in the database are actually correct.
I'm amazed that the whizzy new takeoff/landing algorithm hasn't picked up the fact that VIR22F lands at Heathrow every morning - surely there must be enough network sharers to pick up that one ?
Post by: DaveReid on September 01, 2010, 07:46:52 AM
Quote from: DaveReid on August 30, 2010, 10:55:00 AMAs I said, I don't fully understand the update architecture, so it's possible that over the next few days the refresh process will populate all those alphanumerics.
Today's test shows much the same results, in fact slightly worse than Monday's with 78% of the blank/incorrect LHR routings being alphanumerics.
Has anyone actually seen any signs of the "significant increase" in populated alphanumeric routes ?  Clearly it's not evident at one of the world's busiest international airports, surrounded by dozens of network sharers !
Could AirNav explain how a flight like DLH1VV, which has landed at Heathrow at least 15 times since the new algorithm was supposedly rolled out, has apparently completely escaped detection and is still being reported as Frankfurt-Manchester ?
Post by: neroon79 on September 01, 2010, 08:11:40 AM
To be honest: I can only detect a marginal increase of shown routing Infos here in northern Germany. Further I don't know how many of the "new" routings are correct or still incorrect. I'm checking the EDDV traffic from time to time and for these routings I can say: At least the direction in which the departing Aircraft is flying seems to match with the new routing Information...
As for DLH1VV: Has definitely not shown up on my "space". So the origin seems to be more south of my position/reception area.
Post by: DaveReid on September 01, 2010, 08:18:43 AM
Quote from: neroon79 on September 01, 2010, 08:11:40 AMAs for DLH1VV: Has definitely not shown up on my "space". So the origin seems to be more south of my position/reception area.
  <?xml version="1.0" encoding="utf-8" ?>
- <Flight>
  <FlightNumber>DLH1VV</FlightNumber>
  <Callsign>Lufthansa 1VV</Callsign>
- <Leg>
- <Origin>
  <ICAOCode>EDDF</ICAOCode>
  <IATACode>FRA</IATACode>
  <AirportName>FRANKFURT (INTERNATIONAL)</AirportName>
  <Country>GERMANY</Country>
  </Origin>
- <Destination>
  <ICAOCode>EGLL</ICAOCode>
  <IATACode>LHR</IATACode>
  <AirportName>LONDON/HEATHROW</AirportName>
  <Country>UNITED KINGDOM</Country>
  </Destination>
  <GCDistanceNM>353</GCDistanceNM>
  </Leg>
  </Flight>
Post by: tarbat on September 01, 2010, 08:20:02 AM
Quote from: DaveReid on September 01, 2010, 07:46:52 AMCould AirNav explain how a flight like DLH1VV, which has landed at Heathrow at least 15 times since the new algorithm was supposedly rolled out, has apparently completely escaped detection and is still being reported as Frankfurt-Manchester ?
I guess that if there's not adequate, low-level coverage at Frankfurt (EDDF) as well, then the new algorithm won't operate.  Having said that, coverage at Frankfurt looks pretty good at the moment, but is there adequate low-level coverage when DLH1VV is taking off from Frankfurt?
I also see that Airnav said the they have "deleted all records without origin/destination from our database", so if DLH1VV already had an entry in the database of EDDF-EGCC, how long do we have to wait for this to be replaced with the correct information, and what will trigger this?
Post by: DaveReid on September 01, 2010, 08:54:19 AM
Quote from: tarbat on September 01, 2010, 08:20:02 AM
No argument there.
I think everyone appreciates that if you don't have good coverage at both the origin and destination then it's not going to be possible to work out a route.  AirNav have said that they won't populate routes with an origin but no destination, or vice versa, which is fair enough.
QuoteI also see that Airnav said the they have "deleted all records without origin/destination from our database", so if DLH1VV already had an entry in the database of EDDF-EGCC, how long do we have to wait for this to be replaced with the correct information, and what will trigger this?
Who knows, indeed ?  Only AirNav, and so far they aren't saying.
IMHO, as soon as the network detects a flight with a "known" routing arriving or departing from a different airport on two separate occasions (once could simply be a diversion) then the route should be flagged as potentially invalid in the database until an unambiguous origin and destination are detected.
Of course all the above is only relevant if we're talking about something that has actually been developed and deployed and isn't simply snake oil/smoke-and-mirrors/vapourware ...
Post by: AirNav Support on September 01, 2010, 09:01:43 AM
DaveReid,
Dev knows the in and outs of the system and will explain the details in due time.
It is NOT "snake oil/smoke-and-mirrors/vapourware" as noted when it was released a increase of alphanumeric flights were noticed. As usual you like to cause a bit of controversy in your posts :)
Post by: DaveReid on September 01, 2010, 09:11:12 AM
Quote from: AirNav Support on September 01, 2010, 09:01:43 AMDev knows the in and outs of the system and will explain the details in due time.
I always have trouble understanding Development's explanations of how things work.
Maybe they could explain it to you, and then you could tell us :-)
Post by: anorak on September 01, 2010, 06:09:59 PM
and use words of one sylable/small please.  :-)
Post by: EK01 on September 01, 2010, 06:44:41 PM
Here at Alicante, where there are many Ryanair/Easyjet and Air Berlin flights arriving and departing on a daily basis using alpha/numeric flight id's, the routing information has been  missing for the majority of the flights in spite of the so called 'improvements' to the database. I have certainly seen no improvements.
Post by: neroon79 on September 02, 2010, 06:13:22 AM
Instead of getting more improvements with alphanumeric flight id's I'm getting routing information for the FIS/FCS Aircraft stationed in EDVB now. I guess it doesn't make any sense to provide routings for any FCK*** flights. Or am I wrong here on the plane?
Post by: John Racars on September 02, 2010, 07:49:19 AM
Quote from: EK01 on September 01, 2010, 06:44:41 PM
Is it an idea to ask Ryanair/Easyjet and Air Berlin directly for this information?
Post by: neroon79 on September 02, 2010, 08:01:32 AM
Quote from: John Racars on September 02, 2010, 07:49:19 AM
Of course, if these guys were willing to answer such a question. Has anyone more "official" then me tried this before? Last time I tried I didn't even got an answer.
Post by: DaveReid on September 02, 2010, 08:16:29 AM
Quote from: John Racars on September 02, 2010, 07:49:19 AMIs it an idea to ask Ryanair/Easyjet and Air Berlin directly for this information?
All those carriers are (very) commercial operators.  Even if they were willing and able to supply the data (unlikely) they certainly wouldn't do it for free.
Far cheaper for AirNav to wait for us users to supply updates for nothing !
Post by: EK01 on September 02, 2010, 09:11:25 AM
Quote from: DaveReid on September 02, 2010, 08:16:29 AM
Dave,
I agree with your comments and I certainly will not be supplying the information for nothing. There used to be a monthly publication called the ABC World Airways Guide which, I believe, is now called OAG Aviation. Could AN not purchase this guide and tie up routings/flight numbers. Having said that I have not seen this guide since the ABC days and probably the flight numbers given are different from the alphanumeric flight numbers used by ATC and the air crew. Still I would have thought that a company such as AN (used by major aircraft manufacturers  as we are consistently reminded) would be able to have some influence in getting tie-ups.
Post by: AirNav Support on September 02, 2010, 09:19:47 AM
Thanks Dave once again for your helpfull comment. I think you are guys are forgetting we did join up with FlightStats at a large cost to us to give you Route data.
The alphanumeric flight numbers issue affects all of these flight look up sites. We are not alone in this.
We have implemented the system to try and indentify these flights using departure and arrival airports from the ADS-B positions. This is not 100% and being worked on. There has been many posts about this already and we have explained the issues and also how we are the ONLY ADS-B reciever company who even has attempted to look at this (also applies to aircraft databases)
Post by: DaveReid on September 02, 2010, 11:24:49 AM
Quote from: AirNav Support on September 02, 2010, 09:19:47 AMThere has been many posts about this already and we have explained the issues
On the contrary, unless I've missed it, we're all still eagerly awaiting the post from Development explaining how the system is meant to work.
Quoteand also how we are the ONLY ADS-B reciever company who even has attempted to look at this
Remind me where you got the idea from again, please ?
If you need any help in getting it to work properly, don't be afraid to ask :-)
Post by: AirNav Support on September 02, 2010, 02:53:28 PM
We meant there have been many posts about the issues of getting routes from sites and the alphanumeric issue.
We are the only ADS-B reciever on the market which allows routes look up within the software and has a a link to a online server is updated. None of the others have this, the closest they get is with addons and even a few of them have stopped in the last few months.
Post by: MIKE.UTD on September 02, 2010, 03:08:58 PM
How do I delete the old navdata flight / route info so I can start getting the updates ?
Mike.
Post by: b777200er on September 02, 2010, 05:34:28 PM
I find here in the US that many flight from major airlines are not updated, and have never been update in the data base. US Airways (AWE) flight are not in the data base and have never updated since I have been using RB. Delta flight are out of date and do not update, same for American and Continental.
Donnie
KATL
Post by: DaveReid on September 02, 2010, 06:28:33 PM
Quote from: b777200er on September 02, 2010, 05:34:28 PM
Some AWE flights are in the database, but I've yet to note one that's correct.
Yesterday on the network I watched AWE707 (Philadelphia-Washington) and AWE703 (Philadelphia-Pittsburgh) - both over Ireland !
Sounds like the deal with FlightStats is overdue for renegotiation ...
Post by: DaveReid on September 03, 2010, 12:10:21 PM
While we're waiting for AirNav to (a) explain and (b) fix the routes issue, I've set up a routine that monitors network flights and identifies those where the routing is incorrect or incomplete, using the algorithms that I developed 4 years ago for the EGLL website and subsequently enhanced for www.flightroutelookup.com.
I'll continue posting individual corrections to this thread: www.airnavsystems.com/forum/index.php?topic=5386.0 so that interested users can update their NavData Flights table, but unfortunately time and space won't permit listing of all the incorrect/incomplete flights found.
If it helps in the meantime, here's a list of the affected carriers so far identified:
AAL, AAR, ACA, AEU, AFR, AIC, AMC, ANZ, AUI, AWE, AXM, AZA, BAW, BCS, BER, BHL, BIE, BLX, BMA, BPA, BTI, CAI, CAL, CFG, CKS, CLX, COA, CPA, CRL, CUB, DAL, DLH, EIN, ELL, ETH, EVA, EXS, EZS, EZY, FCK, FDX, FIV, GEC, GFA, GIA, GLO, GLP, GWI, HHI, HLX, IAC, IBE, IRA, JAL, JAT, JSA, JST, KAL, KLM, KRB, LAN, MAL, MDA, MDG, MSA, MSX, NAO, NCA, NKS, PAC, PGT, QFA, QTR, RJA, RYN, RYR, SCX, SHY, SQC, SWR, SXS, TAM, TAR, TAY, TCX, THY, TOM, TRA, TVS, UAL, UPS, VAU, VLG, VLK, VRD, WIF, WOA, WZZ, YZR
HTH
Dave
Post by: EK01 on September 03, 2010, 12:48:08 PM
Dave,
Might have been easier to show a list of the unaffected carriers. Lol
Post by: neroon79 on September 03, 2010, 12:54:05 PM
@Dave
Perhaps it would be easier to list up the carriers which were not affected...
Edit: Not the only one with this thought... ;-)
Post by: eggplant on September 03, 2010, 09:15:57 PM
Quote from: EK01 on September 03, 2010, 12:48:08 PM
Dave,
I wonder if there are any unaffected carriers. Sigh....
