AirNav Radar => AirNav Radar Discussion => Topic started by: davis on March 07, 2008, 08:56:34 PM
Title: Record 0 byte
Post by: davis on March 07, 2008, 08:56:34 PM
Why recordin  is always 0 bytes? I tried to put in DESKTOP--- RECORD ---IN  another folder, but always 0 bytes .. What's wrong?
gianni
(http://img119.imageshack.us/img119/3131/recordza3.gif)
Title: Re: Record 0 byte
Post by: Allocator on March 07, 2008, 09:02:48 PM
Well done Gianni - I do think that you might have found a bug!
This was a problem in a pre release version of RB 2008 but it was fixed in the last version before release.  This must have crept through into the release version.
Over to you Support :-)
Post by: AirNav Support on March 07, 2008, 09:07:55 PM
Noted and confirmed bug, this will be fixed. We are just waiting for any further bug reports over the next week and will work on release to update any issues arising and have that out within a 3 weeks of this release.
Aplogies, if you really need to use the recorder use 1.3 for the meanwhile.
Post by: Allocator on March 07, 2008, 09:12:00 PM
I'm too busy watching live/network traffic, I have no time left to watch recordings :-0
Post by: davis on March 07, 2008, 09:21:29 PM
Quote from: AirNav Support on March 07, 2008, 09:07:55 PM
OK .. So time to make a perfect ver.1.4 and only after a few hours it is not perfect ...Still waiting
Gianni
Post by: Allocator on March 07, 2008, 09:33:25 PM
Keep smiling Gianni - there are more than enough new features to keep you busy until the record bug is fixed - hi hi
Have you tried all the filter and export options in MyLog yet?
All the best from cold and wet England
Post by: AirNav Support on March 07, 2008, 09:33:42 PM
Sorry Gianni, we aren't perfect and neither are you we are humans :)
Post by: tarbat on March 07, 2008, 10:16:27 PM
Strange, it works okay for me.  And this is something I specifically tested during beta testing.  I've been using the recording file all day today to feed into Planeplotter.
(http://img405.imageshack.us/img405/4764/ppeb0.jpg)
The only difference I have noticed is that there's a 5 minute delay before the recording starts - did you wait 5-minutes to see if it started recording?
Post by: Allocator on March 07, 2008, 10:33:31 PM
tarbat, you're quite right!
I'm sure it didn't work like this before :-o
Post by: AirNav Support on March 07, 2008, 10:42:45 PM
Ah yes this was done for a reason :) Too much happening today.
Post by: tarbat on March 07, 2008, 10:56:25 PM
It was an obvious loophole in v1.3 that allowed a real-time feed into other systems.  Good to see Airnav have closed that vulnerability :(
Post by: prbflight on March 08, 2008, 03:31:18 AM
Recorder into PlanePlotter is working fine for me.  Yes there is now a 5 minute delay.
Paul
Post by: Roadrunner on March 08, 2008, 10:50:59 AM
Loophole?
Loopholes are made to be closed as are rules to be broken :-)
Post by: f6gsg on March 08, 2008, 07:45:26 PM
Effectively some times i have a record at 0 Bytes, not often
i try to understand when and how i can do that but it's not
systematic !!!!
More difficult to fix that bug  for Airnav.
Patrick/F6GSG
Post by: Allocator on March 08, 2008, 08:02:24 PM
Quote from: f6gsg on March 08, 2008, 07:45:26 PM
systematic !!!!
Patrick/F6GSG
Patrick, the recording starts 5 minutes after you click "Record".
This is to stop people accessing live data by reading the record file.
It is not a bug.
Post by: f6gsg on March 08, 2008, 09:30:01 PM
Hi Allocator,
i was in a wrong way ... thanks you.
but i have also some freezing problem, not easy to detect:
one time RB goes very slowly with no display for the flight graphical
but OK on the interface !!! and after withe screen (and i have loosing all
the data ...).
i read the informations on the forum and there does not seem of be a link
with internet.
Regreatably freezing took place when I was not in front of my computer,
so it's difficult to have a diagnostic for help AirNav.
Patrick/F6GSG
Post by: davis on March 08, 2008, 10:57:50 PM
iI have  2 time  freezing problem in 10 hours.one this mornig after 4 hours e second this evening after 4 hours ..white screen e comp. freezing .
i Have clenn the register from all voice   radarbox ) e reinstall  1.4 i Expect  tomorrow morning after I leave on all night.
Gianni
This ver 1.4 is making me sweat
Post by: davis on March 09, 2008, 07:27:38 AM
Quote from: davis on March 08, 2008, 10:57:50 PM
Gianni
This morning I found the white screen and the computer freezing.
I remember that last night I clean the registry and installed again.
I believe that the ver 1.4 has more problems 1.3
The 1.3 is not blocked
Ihave simil problem of f6gsg..i have XP PRO  3 Mhz   2 giga ram ...is not old comp.
ciao Gianni Italy
Post by: Allocator on March 09, 2008, 10:09:15 AM
Gianni, I don't think that your computer is the problem, I think that it is that RadarBox does not like it if the internet connection drops for even a very small time.
Switch off your internet and try running RadarBox with live tracks only as a test.  Remember to deselect "share data" in preferences.
Post by: tarbat on March 09, 2008, 10:19:53 AM
Quote from: Allocator on March 09, 2008, 10:09:15 AM
And hopefully Airnav can get a quick-fix out for this problem so that we can be sure that's what's causing these lockups.
I left ANRB running overnight, and also found a white screen lockup this morning :(
