hi lads got a new machine and airnav wont take it hardware showing red usb not reconized help would be grateful nothing to tec not great with computers thanks lads
Are you using Windows 7 64bit?
Download and install the 64bit drivers.
Quote from: rashers on February 12, 2011, 04:56:52 PM
Did you manage to fix it? I am also having the same trouble. :(
P (http://acne.besthelptips.com/)r (http://garlic-breath.besthelptips.com/)o (http://bloating.besthelptips.com/)f (http://back-ache.besthelptips.com/)e (http://bronchitis.besthelptips.com/)s (http://carpet-cleaning.besthelptips.com/)s (http://christmas.besthelptips.com/)o (http://colitis.besthelptips.com/)r (http://dandruff.besthelptips.com/) K (http://dating.besthelptips.com/)i (http://debt.besthelptips.com/)m (http://dinners.besthelptips.com/)b (http://eczema.besthelptips.com/)er (http://diabetes.besthelptips.com/)ley (http://ear-infection.besthelptips.com/) W (http://flies.besthelptips.com/)i (http://gophers.besthelptips.com/)l (http://grey-hair.besthelptips.com/)l (http://groundhogs.besthelptips.com/)i (http://hair-extensions.besthelptips.com/)a (http://headache.besthelptips.com/)m (http://home-repair.besthelptips.com/)son (http://inground-pool.besthelptips.com/)
If you don't have Windows 7 64 bit, try the following steps
http://www.airnavsystems.com/radarbox/help/hardware_connection.htm
http://www.airnavsystems.com/radarbox/help/installation.htm
If you do have 64bit then you need to download the 64bit drivers on our support page.
I am having a similar problem under windows 7.
Rardarbox will run for a couple of hours at most but the the software will say that the box is not connected when it is plugged in. I check the device manager and radarbox is still connected to the computer, but the program is not seeing it.
I have checked that I am running the latest drivers, it is very annoying as I did not have this problem with my old computer running vista.
Any Ideas wopuld be much appreciated.
Try your USB ports/power saver set to see what time outs are set as this is usually where the problems lie on these occasions.
Thanks Very Much.
That has solved the problem. Windows 7 so many tweaks needeed to be learnt again.
Humphrey
