HI LADS ANY IDEA WHEN THERE GOING TO SORT OUT 3D MODELS ALL I HAVE AT THE MO IS RYANAIR AND AERLINGUS THE REST IS GREY SCALES AND NIT SHOWING A LOT OF AIRCRAFT AND COMPANYS
Hi Rashers,
The the new navdata file for 3D is in testing phase at the moment, so hopefully not long.
If its really annoying you, backup your mylog data file and reinstall RadarBox 3D and things copy over the mylog again and things should be back to normal.
SORRY BOUT THIS NOT GREAT IN COMPUTERS HOW DO I DO THIS I WOULD REALY LIKE TO GO BACK TO NORMAL AGAIN THANKS
Firstly there is no need to in capitals, its usually considered shouting on the internet :)
Also can you confirm you did download the database update?
sorry bout the capitals yes i dowloaded the new database
1.) Find your RadarBox folder, it should be in c:\program files\AirNav Systems\RadarBox\Data
2.) Copy the MyLog files to another location
3.) Install RadarBox 3D again.
4.) Copy the MyLog files you copied earlier to the same Data folder mentioned before and start RadarBox 3D.
Quote from: AirNav Support on March 03, 2011, 08:30:47 AM
I have the same 3D model problem.
Ive tried the above. Ive also uninstalled and deleted everything within the Airnav folder, rebooted, re-installed...and its still exactly the same with the original or the new .db3 database.
I wonder if its a Vista x64 bit OS issue ?
cool_1 which specific aircraft and airlines are you not seeing 3D models for?
When you see a model that is all grey/white, check in the GE_Models folder for:
1. A folder named the same as the aircraft's Aircraft Type (eg A321).
2. Within that folder, a folder with the first three letters of the FlightID.
If either of these don't exist, then grey/white is all you'll get.
Well , looking at the UK right now, I have 75% of all the live network traffic showing as white stalks (no 3D models whatsoever !!!), and only a few BA , and Aer Lingus in 3D with liveries. Al the other aircraft around the UK are white 3D models (no liveries).
I cant understand why Im jinxed with 3D. I also had a problem with the 3D interface after a few months, where I could no longer select any 3D aircraft.
I currently have to select 2D Map, then click on an aircraft, and then go back to 3D again before I can view the 3D glide slopes etc.. (I spent a few evenings with development online, and they couldnt fix that either) . I even tried it on another laptop (XP). and...same issue... ?
My settings are on the highest setting. However its a 3.0 quad core PC (8GB RAM), and should have no problems with applications set to the max. (Vista 64 Bit)
Tarbat- thanks for the suggestion.
OK so lets see..
I have attached a photo of a RyanAir flight on my 3D interface. As you can see , no liveries...just a white 3D model. So if I look at the GE folder you suggest (B738 subfolder RYR), I see one file called 'texture.liv' (146K in size)
Does that help ?
I note that you are using Vista, do you have airnav installed to the default C:\Program files\Airnav?
If so install it in C:\Airnav and see if that improves mattesr.
Hi Alan, I completely uninstalled (through Control Panel) , deleted the Airnav folder, and installed from scratch on a different partition and folder (ie. D:\3d )earlier today. Made no difference.
The last thing I tried earlier today (through desparation) was to uninstall Nortons Antivirus, and load Avast as a complete change of AV software ...then reloaded Airnav from scratch into the default folders. This is why Im back in the 'default' folders right now. I thought that would fix it too !!!
Here is another example of the GE folder contents: (this time where there is no 3D model, and just a white stalk.)
Its beyond me, I havent a clue, sorry cant help you.
Here is one more example nicely showing 2 examples in a single snapshot, side by side, along with their GE folder contents.
This time with EasyJet (blank white model), and BMI (perfectly normal with full livery). Interestingly they both have 2 files in each folder !
And if we pan along a little bit more across the 3D wilderness....this is a typical view of what I get.
It looks to me like some kind of 3D Prototype windfarm in the English Channel !!!
So its back to 2D and planeplotter for me.
Cool_1 are you trialing the 3d navdata for Airnav as mentioned in the first reply to this topic?
The examples above are with the base 3D (4.03 ) fresh install.
I have now just installed the trial .db3 (which airnav sent me a few days later) and get exactly the same issues.
For example I have attached a sample with the latest 3d navdata. (this time a BA A320 - again no 3D model).
Hope it helps Airnav.
We are working on this at this time. Stby for further news within the next 24 hours.
We are still working on this one.
Airnav
Rough timescales??? and the issues during the testing that have caused the delay during testing are?????
Sorry more questions than answers given again
We are resuming work on this as I type this message.
Quote from: AirNav Development on March 06, 2011, 02:38:50 PM
Hi Airnav,
Dont want to jump the gun but....the 3D is looking promising again...Im just about back to normal right now with most of the liveries showing at last.
Im running with the test database you sent me the link for , after I originally reported the issue.
As you can see on this snapshot, a noticeable improvement. (fingers crossed its all fixed soon). If you need any more testing, let me know.
regards,
Jon
But we haven't changed anything on the server! Isn't it your computer? :-)
Theoretically all should be working Ok since the last navdata.db3 upgrade and we were trying to understand why it didn't.
cool 1 what test database did you get some planes are showing for me a lot are not though i think its not sorted yet
Clearly still have a problem!
I have lost all 3D skins for easyJet, Ryanair, Emirates, Ethiad amongst others...
Strangely have gained 3D visualisation for BAW planes on shuttle flights.
Please keep working on this AirNav! Can't just be Cool_1's computer - although very strange that he's managed to post a screenshot with easyjets....
Pinza: which navdata.db3 database you've installed?
AirNav,
Same for me with Easyjet and Ryanair, with latest NavData installed.
Quote from: AirNav Development on March 07, 2011, 09:56:59 PM
Airnav,
OK... I will go out and buy a new computer. ;-)
Andrewarles,
I have attached some shots for the same models. As you can see my Ryanair and EasyJet seem to be working better on the newer test .db3. (I have no idea what the difference in the databases is ...except a few more 3D models seems to be working now !?)
Rashers,
I basically have a test database that Airnav sent me a link for, just a few days after the original new .db3 release.
However I STILL have a major problem with 3D, especially when you pan away from the UK. As can be seen in the third shot. Lots of empty white 'stalks', and no 3D models whatsoever.
yeah cool 1 same problem here a joke id say they dont seem to have the answers
We apologise for the issues caused and we are doing our best to find the cause and rectify it asp.
Quote from: AirNav Development on March 08, 2011, 11:24:24 PM
This is the database that I downloaded in good faith and started the cause of my missing 3D skins:
http://www.airnavsystems.com/Download/ANRB/DBUpdater/ANRBDBUpdater201102.exe
Look forward to a solution!
Try this one:
http://www.airnavsystems.com/Download/ANRB/DBUpdater/ANRBDBUpdater20110225.exe
Screenshot after installing the latest NavData.db3.
All 3D models have disappeared.
Quote from: AirNav Development on March 10, 2011, 12:16:20 AM
Try this one:
Many thanks AirNav - have just downloaded and installed the updater you pointed me to.
This has given me back correctly rendered 3D skins for at least easyJet and Ryanair. Will monitor the situation for any missing skins that I used to have.
Attach screenshot.
Chris
Hmm, A6-EBV just overflown my house on flight UAE38 - the evening Birmingham to Dubai flight.
Has reverted to a grey 'skinless' version - has always had a full skin until I installed latest updaters!
Is it related to the fact that the aircraft type is showing as B77W rather than B773?
yeh i have the 737 back but not the big ones 777 747 330 etc
Hi Airnav,
any updates on a possible 3D fix please ?
My 3D interface is really unusuable due to this bug (and also a previous bug which I reported a year ago, where I cannot select aircraft on the 3D google map, and still no fix ...ie. Airnav support ticket #76559). I therefore have to select an aircraft on the 2D display (works fine), and then switch to 3D...only to see a white stalk or blank aircraft after all the hassle.
Its rather frustrating after paying good money for a 3D upgrade, and cannot use.
thanks
Earlier today I downloaded and installed http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20110313.exe
As documented on the thread relating to this updater, it installed in wrong directory - however successfully copied it across to where it belonged and have been running it for a few hours now.
I'm fairly happy with it but still have a problem with 'grey' planes flying around the Midlands!
It appears that I'm not alone with this problem - just wondering whether it is worth starting a new thread for missing skins? By this I mean a dedicated thread for missing skins with the details of the airframe that is missing - rather than a vague moan that I'm missing loads...
This might be more useful to AirNav to narrow down where the problem lies - any thoughts?
Before I (or anyone else) starts such a thread, this is what I am missing this evening:
HB-JVF F100 4B19EB Helvetic
G-OOPT A320 400953 Thomson
G-TOYK B733 401122 BmiBaby
LN-DYB B738 478538 Norwegian Air Shuttle
HA-LPI A320 473409 Wizz Air
EI-RJR RJ85 4CA4C3 City Jet
A6-EBV B77W 8960DD Emirates
All of the above created a correct 3D image but grey - ie no livery.
Certainly my Emirates flights always used to show correctly before I started updating my Nav.data.db3 file !!!
Quote from: Pinza on March 19, 2011, 09:05:56 PM
There is certainly a bug that needs urgent attention. But most of the examples you give will not have skins because Airnav never created them!
HB-JVF F100 4B19EB Helvetic - OAW F100 skin never created by Airnav
G-OOPT A320 400953 Thomson - TOM A320 skin never created by Airnav
G-TOYK B733 401122 BmiBaby - Airnav created a B733 for BMA (the main airline). The last B733 left that airline in 2007, 3 years before the creation of 3D. They did not create a skin for bmiBaby BMI B733
LN-DYB B738 478538 Norwegian Air Shuttle - NAX skin never created by Airnav
HA-LPI A320 473409 Wizz Air - WZZ A320 skin never created by Airnav
EI-RJR RJ85 4CA4C3 City Jet - Airnav created a B463 for BCY. The last 146-300 left that airline in 2004, 6 years before the creation of 3D. They did not create a skin for BCY RJ85
A6-EBV B77W 8960DD Emirates - Airnav created UAE skins for the other three 777 types operated by the airline B772, B773, B77L. But never created a B77W for any airline.
If you look in the GE models folder in your Airnav folder on your computer, you will be able to see which of the aircraft types should show a skin.
Hope this helps you identify which ones should not be blank and have a bug against those that were never created with the original 3D release.
Regards ACW367
Thanks ACW367,
Rather late - and must a-bed - will re-read your reply when I'm fresh in the morning!
Sounds like the latest NavData.db3 update has nothing to do with my problems - just missing skins from the original 3D release!
Will play with copying textures into new folders under my GE models folder. (Having backed everything up first!)
Chris
Quote from: ACW367 on March 19, 2011, 11:23:30 PMIf you look in the GE models folder in your Airnav folder on your computer, you will be able to see which of the aircraft types should show a skin.
If this helps. Here's a list of each aircraft type with associated Flight IDs that will generate a 3D model with airline colours:
A300 FDX KAC MON QTR UPS
A306 FDX KAC MON QTR UPS
A310 FDX KAC PIA RZO SBI THY TSC
A318 AFR FFT MXA ROT
A319 AAF ACA AFL AFR AWE AZA BAW BER BMA CCA CNT CYP DLH EZS EZY FFT FIN GWI IBE ISS LHI MXA NKS NWA SAA SAS SBI SHT SWR TAM TAP TAR UAL VRD
A320 AAF ABY ACA ACM ADR AFL AFR AIC AJM ANZ AUA AWE AXM AZA BAW BER BGH BMA CIB CSA CSN CTN CYP DAL DLH EDW EEZ EIN EZY FCA FHY FIN GWY IBE IWD JBU JKK JST KFR LBT MON MSR MXA NLY NWA QTR RJA RZO SHT SWR TAM TAP TAR TCW TCX TGW THY UAL VIM VLG VRD
A321 AAF ABY ACA ACM ADR AFL AFR AIC AJM ANZ AUA AXM AZA BAW BER BGH BMA CIB CSA CSN CTN CYP DAL DLH EDW EEZ EIN EZY FCA FHY FIN GWY IBE IWD JBU JKK JST KFR LBT MON MSR MXA NLY NWA QTR RJA RZO SHT SWR TAM TAP TAR TCW TCX TGW THY UAL VIM VLG VRD
A332 AEA AFR ALK BER CES CSN EEZ EIN ETD EVA JST KLM LVG MON MPD MSR NWA QTR SWR TAM TAP TCX THY TSC UAE USA
A333 ACA AWE CAL CES CPA DAL DLH EIN GIA HDA IWD KAL LTU MAS NWA QFA QTR THA TSC
A343 AFR ALK CES DLH FIN IBE MAU MPD SAA SAS SWR TAP THT THY UAE VIR
A345 ETD QTR SAA UAE
A346 DLH IBE QTR SAA THA VIR
A380 AIB QFA SIA UAE
AT42 CAV CFS MTN
AT72 EFG
B462 AEE BCY BEL BLF BRT DLH FLI SWR
B463 AEE BCY BEL BLF BRT DLH FLI SWR
B717 HAL MEP TRS
B722 AJT CCI CJT FDX KFA
B732 AAH ANT BHS FAB PCE
B733 AEE AUI AWE BAL BMA COA DLH EXS FPO GMI JAT KAJ KNI LZB NAX OAL ROT SWA TAY UAL VEX
B734 ADH AEE AEW ASA AUI AWE BAW BEL CSA OAL SHY TSO VEX
B735 AUI BRU BTI COA DLH LGL LZB SWA TAR TVS
B736 BRA DAH MAH SAS TAR WJA
B737 AAH AEU AMX ASA AUH AZI BER BRA CCA CDG CES CGN CHH CHP CMP COA CSH CSN CSZ CUA CXA CXJ DAL DAN DNV EZY FJI GLO GMI HHI HLF HLX JAI KQA LCD LDA LGL MAH OMA PTI RAM ROT S2 SAS SCX SEY SNG SWA SXS TRA TRS TSO VOZ WJA
B738 AAL AEA ASA AUA AXB BER BSK CJA COA DAH DAL ECA ELY GSM HLX JAI KLM KYV LDA MAH PGT QFA RAM RYR SAS SCX SWG SXS THY TOM TRA TVS VOZ WJA
B739 ASA COA KAL KLM
B742 CKS EIA GTI NWA SVA
B744 AAR AFR AIC ANZ BAW CAL CCA CLX CPA CRL DAL DLH ELY EVA GTI JAL KAL KLM MAS NCA PAC QFA SIA SOO SQC SVA THA UAL VIR
B74F CLX GTI JAL NCA PAC SIA SOO
B752 AAL AEU COA DAL DLH ERO EXS FDX FIN ICE MON NAO OAE SXS TCV TCX TOM UAL UPS UZB
B753 AIZ CFG COA DAL ICE NWA TCX
B762 AAL ABX AWE COA ELY TPA TSO USA
B763 AAL ABX AFL ANA AWE AZA BAW BPA CCA CFG COA DAL ELY ETH GSM HAL JAF JAL LAN LOT MON MPH NAO RAM TOM TPA TSO UAL UPS UZB
B764 COA DAL
B772 AAL AAR AFR AIA ANZ AZA BAW CCA COA CPA CSN DAL ELY HVN JAL KAL KLM KQA MAS MSR PIA SIA SVA THA UAE UAL
B773 ACA AFR ANA CPA ETD EVA KAL SIA UAE
B77L ACA AFR ANA CPA ETD EVA KAL SIA UAE
CRJ2 ASH AWI CAA CHQ COM FLG JIA JZA MES SKW
CRJ7 ASH CAA COM EFG GJS JIA QXA SKW
CRJ9 ASH COM FLG FRL JZA MES SKW
DC10 AFL APW CIU FDX OAE WOA
DH8A AIE BHS CJC CRQ ERH JZA LGL LIA MKU PDT POE QXE SSX USA
E120 GLA SKW
E135 CHQ EGF
E145 ASH CHQ COA EGF LOF SLI USA
E170 RPA TCF
E190 ACA AWE JBU VOZ
F100 AFR AUA KLM OAW PGA
F70 AUA KLM MAH
IL96 AFL CUB
MD10 AFL APW CIU FDX OAE WOA
MD11 AFL DLH FDX FIN GEC KLM SVA UPS WOA
MD83 AAL AAY BUC DAL OHY
MD90 DAL SVA
Thanks for that list Tarbat - it appears that my grey planes aren't in it - explains a lot!
Chris
