AirNav Radar => AirNav Radar Discussion => Topic started by: marcdeklerk on March 18, 2008, 02:28:58 PM
Title: Mode S generator - pattern
Post by: marcdeklerk on March 18, 2008, 02:28:58 PM
hi there guys, I was wondering:
The mode S code of each aircraft is unique to each aircraft, in South Africa where I a located, I have noticed the folowwing:
ZS-AAA  ---- 008000 ?
ZS-ZZZ  ---- ???????
so the rest of the registrations should be between 008000 and ?????
ZS-ABG 008031(the closest to AAA that I have logged)
ZS-ZXX 00C482 (the closest to ZZZ that I have logged)
ZS-SLA 00B0B7
ZS-SLB 00B0B8
ZS-SLC 00B0B9
ZS-SLD 00B0BA
ZS-SLE 00B0BB
ZS-SLF 00B0BC
there is a pattern
ZS-SJR 00B094
ZS-SJS 00B095
ZS-SJT 00B096
ZS-SJU 00B097
ZS-SJV 00B098
could some maby generate all the registrations with their Mode S? and then I can have a look at the one's thats not updated by the Auto-Populate feature and add them in myself?
will this work?
Title: Re: Mode S generator - pattern
Post by: tarbat on March 18, 2008, 02:34:10 PM
This SQL will give you the list of 80,000+ aircraft, listing their ModeS hexcode and registration:
SELECT DISTINCT
  aircraft.MS,
  aircraft.AR
FROM
aircraft
ORDER BY
  aircraft.MS
Although I suspect there'll be many exceptions
Post by: Allocator on March 18, 2008, 02:43:12 PM
Quotecould some maby generate all the registrations with their Mode S? and then I can have a look at the one's thats not updated by the Auto-Populate feature and add them in myself?
Nice idea, but it's not quite that simple!
Mode S allocations to registrations are often quite random, even though certain code blocks are allocated to particular countries or operators.
Post by: steveb25 on March 20, 2008, 04:14:46 PM
Apologies slightly off topic
what is the wildcard character for sqlite?
Post by: tarbat on March 20, 2008, 04:33:12 PM
Quote from: steveb25 on March 20, 2008, 04:14:46 PM
Either * or %
Post by: steveb25 on March 20, 2008, 04:44:35 PM
Thanks tarbat
I was trying to use '=' and not 'like' to sort data
