AirNav Radar => AirNav Radar Discussion => Topic started by: Johnn on May 16, 2011, 12:35:10 AM
Title: Will I lose alot of signal if I split the airnav antenna between 2 devices?
Post by: Johnn on May 16, 2011, 12:35:10 AM
Title: Re: Will I lose alot of signal if I split the airnav antenna between 2 devices?
Post by: Aerotower on May 16, 2011, 09:12:20 PM
Use a spliter and not a T, so do not lose signal.
Post by: MW0CVW on May 16, 2011, 09:23:42 PM
Johnn,
You will lose some signal if you connect two devices to the same antenna.
Martin Lynch has the following item or check web.
The SP – 3 (RF Systems) splitter makes it possible to connect two receivers simultaneously to one wideband- or VHF-UHF output of an indoorunit. Both receivers operate if they are connected to their own antenna.
The high isolation of this splitter assures that both receivers are completely separated: there is no mutual influence such as signal loss or birdies generated from one receiver into the other. The frequency range of the SP – 3 covers 10 MHz – 2500 MHz.
This will stop any interaction between the two receivers and keep loss as low as possible.
There will be some signal loss but thats price you have to pay.
Good quality coax and connectors must be use at all times.
Paul Mw0cvw EGGP/EGNR
Post by: Thehall on May 17, 2011, 03:01:24 PM
QuoteYou will lose some signal if you connect two devices to the same antenna.
If anybody is interested in a SP3 Splitter, I have a secondhand one for sale.
Post by: Johnn on May 17, 2011, 05:41:45 PM
Am I right in thinking with a splitter I could have radarbox and a scanner off of one antenna? ( Both of which work off the same antenna well)
Post by: Evanelpus on May 17, 2011, 06:28:40 PM
I don't think the RadarBox antenna is designed for use with a scanner so it could be academic.
Post by: Runway 31 on May 17, 2011, 06:30:30 PM
I dont think it would be a good idea to use the one antenna for both radarbox and radio.  Radarbox is better using one dedicated to 1090Mhz and radio 108-136Mhz.
Post by: Evanelpus on May 18, 2011, 03:43:49 PM
I think Alan has summed it up better than I did, that's what I meant to say
Post by: Johnn on May 19, 2011, 10:25:03 PM
Thanks for all the answers!
