Hi, i have just installed this great programme . but have major properleum, when i open settings the window does not go to full size half of settings are missing in the window hope some one can help i can,t set any settings Grateful of any help Jim
Please try the following:
1.) Change to small Fonts (you should be able to do this from your control panel)
2.) Increase your resolutions to the max you can
3.) If you have a mini laptop, some allow you to expand the viewable screen size temporary so you can view it.
4.) As a last resort you can use the software below to resize it
http://www.softpedia.com/get/System/System-Miscellaneous/ResizeEnable.shtml
Thank you support, method .1. fixed properleum Best regards Jim
