is it possible to use the ACARSD software with the radarbox software? I want to use it together with the ACARS-Tab in the Radarbox software and have the data displayed when I check the "Connect to AirNav ACARS Decoder" box.
I think you'll need to use the Airnav ACARS decoder if you want to use the ACARS tab in Radarbox - http://www.airnavsystems.com/ACARS/
Hi Henning,
yes that is possible,i am running it as folows
On the main computer i am running radarbox and on a different computer in the network
acarsd1.70,hooked up with a scanner
Then inside acarsd you will receive your acars message and also traffic from radarbox
it is possible to run acarsd and radarbox on the same computer
If you want a config file of acarsd from me no problem.
Greetings
Ronnie
Hi Henning,
Have a look at http://77.171.116.209:8080/ (the fast way)
http://www.radioham.nl is my domain,joomla installed
good luck
Ronnie
