AirNav Radar => AirNav Radar Discussion => Topic started by: Briboy2008 on March 21, 2008, 09:14:13 PM
Title: ACARS decoder
Post by: Briboy2008 on March 21, 2008, 09:14:13 PM
Hi All,
A total newbie here trying to get to grips with my AirNav unit. I noticed that the ACARS decoder window is empty. Does this mean I have to buy extra software for this to work? And is it worth the money?
Would appreciate your advice.
Brian
Title: Re: ACARS decoder
Post by: Bigyun2000 on March 21, 2008, 10:20:18 PM
Briboy2008
Hi mate  Yes you have to buy the ACARS Software.  You can then either use the ACARS software thru Sound Card and a receiver/scanner or you can use the internet.
I have the ACARS software linked to the internet.  Works very well.
Hope it helps you
Tony
Post by: AirNav Support on March 21, 2008, 10:22:03 PM
The ACARS Decoder window is an interface to the software ACARS Decoder.
What that means is, if you have then ACARS Decoder running the entries will also be displayed in RadarBox. Its a nice to way have both RadarBox Data and ACARS data together.
Its nice to see the engine config data and route before they takeoff (through acars messages) and then see the aircraft on RadarBox.
Post by: Briboy2008 on March 22, 2008, 08:09:44 AM
Thats great, many thanks for getting back to me on this.
Brian
Post by: Briboy2008 on March 23, 2008, 01:33:16 PM
I have now purchased and downloaded an ACARS decoder. However it still does not appear in my NavRadio interface. When I click on connect to ACARS decoder it says I have to be connected to ACARS which I am. What else do I have to do to make this work? I can watch it in a seperate window but that is not the point really.
Can anyone help please?
Brian
Post by: Allocator on March 23, 2008, 02:02:56 PM
Quote from: Briboy2008 on March 23, 2008, 01:33:16 PM
Brian
Are you running RadarBox V1.5?
Post by: Briboy2008 on March 23, 2008, 02:22:36 PM
yes
Post by: pcochrane12 on March 23, 2008, 02:29:06 PM
brian
ive found i need to have acars running before i start the rb then select in rb acars screen to connect to the decoder
cheers paul
Post by: titigti on March 23, 2008, 02:33:31 PM
same here, first start acars decoder and then your RB ;) and then I start airnav suite, so also acars position reports show up in a map.
Tchau,
Etienne
Post by: pcochrane12 on March 23, 2008, 02:38:35 PM
yep etienne
thats how i do it would be nice to have them show on the rb screen but at least running airnav suite means you can see them even if you have to keep switching between the two
cheers paul
Post by: Allocator on March 23, 2008, 02:54:56 PM
Quote from: Briboy2008 on March 23, 2008, 02:22:36 PM
yes
OK, I run RadarBox V1.5, then I run ACARS Decoder 2.  I tick the box in the RadarBox ACARS tab "Connect to AirNav ACARS Decoder" and it just works.
I'm using ACARS Decoder with internet data as I don't have a dedicated ACARS radio receiver at the moment.
Post by: pcochrane12 on March 23, 2008, 03:01:18 PM
hi allocator
running v1.5 with eiter icom pc1000 or bearcat780xlt as a dedicated acars reciever but am not connected to the internet due to reasons posted else where so may be its because im not on the internet causing the startup procedure both etienne and myself use
cheers paul
Post by: AirNav Support on March 23, 2008, 04:10:58 PM
That shouldn't be a problem, whether the data from acars is local or network it still should get displayed.
Are you using Vista?
Post by: pcochrane12 on March 23, 2008, 04:50:49 PM
no not running vista running xp pro just turned acars decoder off while running live flight tracker and couldnt get back on there either had to restart flightracker and then switch on decoder link again
Post by: Briboy2008 on March 23, 2008, 05:42:56 PM
That did the trick, I was starting the programs the wrong way around. Starting the decoded first was the answer. Thanks for all your help you guys.
Brian
Post by: pcochrane12 on March 23, 2008, 05:48:51 PM
brill enjoy using it
Post by: Deadcalm on March 24, 2008, 08:52:04 AM
I'm thinking about downloading the ACARS decoder, but I don't think I'd get away with another (larger) external antenna for my ageing Signal R-535 receiver.  Do I correctly understand there to be ACARS data websites I can tap into for currently updating information?
DC
Post by: Allocator on March 24, 2008, 09:02:26 AM
Quote from: Deadcalm on March 24, 2008, 08:52:04 AM
DC
There are a number of internet ACARS servers which can be used by ACARS Decoder 2 without having to use your own radio receiver.  See the list of the left in the screenshot.  In this case, I'm using the Sheffield UK internet server.  Not all of those in the list are working all the time, and the list does change a bit day by day.  If you use the internet ACARS servers, you are always going to be picking something close to you, but it might not be exactly in your location.  With a radio receiver linked to Decoder, then you are obviously going to get the traffic in your area.
You have the option of using a radio and/or the Internet with Decoder.
(http://farm3.static.flickr.com/2195/2356764971_ec065a1d6c.jpg)
Click the link below for the full size screenshot.
http://farm3.static.flickr.com/2195/2356764971_2edd908969_o.jpg
Post by: Deadcalm on March 24, 2008, 09:35:09 AM
Thanks, Allocator, worth thinking about.
DC
