hi all,
i have just got a radarbox and when i use it with the internet i get lots of aircraft but if i don't use the internet i only get maybe five aircraft on my screen,
does this mean i have to have the internet on my radar box,
or do i need to change some setting's,
i am new to this so any help and i will be so gratful,
regards iron
Hi Iron,
If you are not connected to the internet you will only see the flights you are picking up using your antenna. If you are connected to the internet you will also pick up network traffic being supplied by users worldwide.
Crocman
The aircraft from the internet are those detected by other users who share the data.
When you disconnect the internet what left is what your ANRB is detecting aircraft in your area.
If you are only getting a few aircraft you have to remember that it only detects aircraft by line of sight so you need to get your arial as high as possible to avoid building or hills etc.
Brian
Hi Crocman, as Brian says you need to site your antenna as high and in the open as possible, if it's indoors on the window sill for example, you'll only get the a/c that the aerial can "see" and glass (especially double glazed and heat reflective type glass) will attenuate (reduce) the signal sometimes quite dramatically. HTH
thank you so much for all your help,
i will be putting a antener on the roof,
does anyone know where i can get a antener from,
regards iron
Iron
AirNav have just started this thread: http://www.airnavsystems.com/forum/index.php?topic=6844.0
Hi iron, others are available : try Googling :- Radar Extender, Radar Rama, and SSE's 1090SJ MkII.
hello,
would this be any good or is it to cheap,
cost about £50 on ebay
Radar-Rama-ADS-B-1090MHz-Virtual-Radar-Base-Antenna
Its been mentioned on here so should be suitable.
Crocman
I've got a Radar Rama 1090 and had it for about 18 months with no problems. I was was worried about being so slight high winds/frost might cause problems but none seen.
Brian
