AirNav Radar => AirNav Radar Discussion => Topic started by: orkney on October 26, 2012, 02:19:22 PM
Title: New Navdata.db3 - 20121025
Post by: orkney on October 26, 2012, 02:19:22 PM
Hello
Once again, The new Navdata Installer can be downloaded from the link below:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20121025.exe
Thank you
Andrew
Title: Re: New Navdata.db3 - 20121025
Post by: nortonbeak on October 26, 2012, 08:13:32 PM
Thank you most heartily for your efforts.
I for one, certainly appreciate the efforts that are required to keep it up.
Post by: Kenny on October 26, 2012, 09:51:03 PM
Installed without any problem..  Thanks a lot..
Post by: Northern Watch on October 27, 2012, 07:44:44 AM
Thanks again for all your efforts.
keith
Post by: vena on October 27, 2012, 07:48:59 AM
Good work :-), thanks.
Post by: AV61 on October 28, 2012, 10:41:05 AM
how many aircraft should there be in the database now as i am showing 168113
thanks
Nick
Post by: Runway 31 on October 28, 2012, 11:09:53 AM
I belive it should be around 188,000.  Looks like you are still looking at an older Navdata.
Look to where you are installing too.
Post by: AV61 on October 28, 2012, 11:13:04 AM
Thanks for that Alan  now have 188030
I appear to have a virtual store where my downloads prefer to go to so have deleted that and
now all is ok
thanks
Nick
Post by: Canonjohns40D on October 28, 2012, 11:50:18 AM
For me being older etc etc!!!. Where do you see the figure 188030 please? If I select the aircraft list in Database explorer I see a figure off 81134. I've proably done something wrong or looking in the wrong place? Any help welcomed.
Post by: Runway 31 on October 28, 2012, 12:13:39 PM
John,
The figure mentioned can be found as follows;
File/Database Explorer/Aircraft  bottom left of the box it will show ******* rows loaded in **m/s
If you dont have 188,*** you are not using the latest Navdata
Post by: Canonjohns40D on October 28, 2012, 12:36:10 PM
Hi Alan thanks that is where I am seeing the figure 81134. I have tried to downoad the file from the site here but obviously did some thing wrong. Thanks for the reply.
Post by: Runway 31 on October 28, 2012, 12:53:48 PM
You need to direct it to Airnav systems/Radarbox wherever you have it installed the box software too.
Post by: Canonjohns40D on October 28, 2012, 03:56:35 PM
Arrrggggghhhh! I can't get this right. Off to see the match.
Post by: Runway 31 on October 28, 2012, 04:32:14 PM
Give me shout later John and will talk you through it
Post by: Canonjohns40D on October 28, 2012, 09:28:19 PM
Hi Alan I downloaded the file and did a save as entering it into where I believe the correct Airnav folder in my C Drive? I stil have 80*** odd aircraft/ Any help appreciated.
Post by: vonsmalhausen on October 28, 2012, 09:51:34 PM
maybe this helps ; when i excecute the exe file of the update, it points me out to something like
c:\airnav Systems\airnav radarbox\data
delete the "data" part in this path, and it extract to the right place
Post by: vonsmalhausen on October 28, 2012, 09:55:40 PM
btw, if you used the standard extraction form, you should have a "data" folder in the actual RB "data" folder, containing the newest DB3 file
Post by: Runway 31 on October 29, 2012, 08:04:25 AM
Once you have saved the filre, you still have to go through the installation process to extract the data.
Use windows search to look for all occurances of Navdata db.3 to see where they all are.  You obviously have more than one Airnav version and it is going to the wrong one for the data.
If you installed the origional disk and then installed the 4.03 or 3.13 versions you will have two versions in different places.  Yoy require to find the path to the version you use and only go as far as Airnav Systems Radarbox, dont go as far as data as the innstaller puts it in the data folder.  If you find the correct and wrong Navdata you could always moves the new one over and replace the older version with the new one.
What version of windows do you use.
Post by: dca on October 29, 2012, 10:57:18 AM
I have installed the new Navdata db as per the link in the first post by Orkney.
I now have a number of flights (inc EZY & RYR) showing route KLAX-ELXX!
Is there any good reason why this is happening please?
Thanks,
Dave
Post by: Runway 31 on October 29, 2012, 11:00:08 AM
Can you give some examples of these to allow me to search please.  I have had a look in my d/b explorer Routes and there is no ELXX to be seen.
Post by: dca on October 29, 2012, 11:11:52 AM
Please see the attached file, the offenders are highlighted!
Post by: Runway 31 on October 29, 2012, 11:40:27 AM
DCA
ELLX, you stated ELXX in your original message.
I have had a look at those highlighted and none of them are in my database.  To have the routes displayed you must have them in your database explorer.  Have a search for these using your database explorer searching the FN field which is the flight number, the flight number and to and from point must be in the routes d/b to display
I had MAC2105 earlier and it was not displaying a route and have noted it in a spreadsheet for updating later.
As the winter season started yesterday most of my EZY flight are not showing routes.
I can only think you have a corruption of some sort and would suggest you re-install the update.  Is  anyone else exhibiting this problem?
Post by: jim_stockwell on October 30, 2012, 06:38:04 PM
Thank you for all efforts. Once you get the path correct, thank you Alan,any update is very straight forward
Jim
Post by: atlantico on November 13, 2012, 04:20:59 PM
Following this link: http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20121025.exe
I get the information "page not found"!! Some help will be appreciated. Thanks.
Luis
Post by: RodBearden on November 13, 2012, 04:51:27 PM
Hi Luis
Right-click the link and choose "Save link as..." or "Save target as..."
Once you have saved it, double-click it to run it.
Hope that helps
Post by: atlantico on November 13, 2012, 06:36:23 PM
Hi Rod,
Thank you so much for the answer. Unfortunately doesn´t work. My browser, by default, is Firefox. I also tested on Chrome without success! This is weird!
Luis
Post by: Ringwayman on November 13, 2012, 07:47:22 PM
Hi Luis,
Glad I'm not the only one experiencing this issue. I sent an e-mail to systems support yesterday and they have forwarded it on to the technical department.
I've not heard anything as of yet.
Simon.
Post by: RodBearden on November 13, 2012, 07:53:09 PM
Yes - you're right - just tried it myself and it doesn't work :-(
It used to work fine - let's hope Support get it fixed.
Post by: dantheman on November 13, 2012, 09:04:48 PM
Link is still broken. Anyone got a copy? I'll gladly host it for download until the link gets fixed.
Post by: atlantico on November 13, 2012, 09:16:11 PM
Hi, all,
I´m glad, finally I´m not alone ;)
Luis
Post by: RodBearden on November 13, 2012, 09:40:31 PM
OK - I've hosted it - try saving this link: http://www.rbearden.toucansurf.com/ANRBDBUpdater20121025.exe
I'll keep it here until Support fixes it or until the next update is issued.
Post by: atlantico on November 13, 2012, 09:56:55 PM
Thank you, Rod. I got it. Working.
Luis
Post by: Runway 31 on November 13, 2012, 10:00:55 PM
I'm looking at doing a new one tomorrow
Post by: RodBearden on November 13, 2012, 10:11:47 PM
Glad you got it, Luis.
Thanks Alan.
Post by: Ringwayman on November 14, 2012, 02:09:05 AM
Thanks Rod
All sorted!!!
Simon
Post by: dantheman on November 14, 2012, 08:28:14 AM
Link is back again. Here is a copy at RadarSpotters.eu in case it's ever needed.
http://www.radarspotters.eu/software/ANRBDBUpdater20121025.exe
(http://www.radarspotters.eu/software/ANRBDBUpdater20121025.exe)
Post by: Canonjohns40D on November 14, 2012, 04:12:17 PM
Hi I never did manage to get the current update to load. I note Alan is considering the next one today so; before trying again!
Do I need to load these in sequence and can someone do me the idot; an idot's giude to installing please?
Just to add when I click File, database explorer and select aircraft I have 81555 shown.
Post by: Runway 31 on November 14, 2012, 04:30:46 PM
John,
As the Navdata link is working again I am not doing an update today.
Before being able to assist I need to know where you have installed Radarbox on your computer, can you advise.
If you installed off the disk and then upgraded t oa later version you will have at least two NavData.db3 files on your computer.  Can you use windows search to find them and advise where they are.
Use windows search to look where it is
Post by: Canonjohns40D on November 14, 2012, 04:51:35 PM
Hi Alan
Thanks I'll check this out but it mght be tomorrow before I can advse you. I have a carers meeting tonight as since my wife's passing I have sole responsibility for my Daughter who is disabled.
I'll check windows search and see where Radarbox is on the PC. I very much appreciate your assistance.
Post by: Runway 31 on November 14, 2012, 05:28:44 PM
No worries John, whever you are ready.
Post by: Canonjohns40D on November 14, 2012, 05:32:59 PM
Hi Alan
I found this?
"C:\Program Files (x86)\AirNav Systems\AirNav RadarBox 2009\AirNav RadarBox\ANRB.exe"
"C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\ANRB.exe"
The desktop Icon I click to start the box properities shows this as it's link.  "C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\ANRB.exe"
Does this help or hinder?
Post by: Runway 31 on November 14, 2012, 05:39:59 PM
John,
That being the case you should download and install the update to C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\
Please note as you have used the default program files location you may have some problems.  If its been working OK until now, keep you should be OK, fingers crossed
Post by: Canonjohns40D on November 14, 2012, 05:54:30 PM
Hi Alan
Thats what I believe I was doing and just tried without success.
I'm off out now so I'll check back later or tomorrow.
Thanks anyway for your help.
Post by: Kenny on November 17, 2012, 05:50:04 AM
Link is broken.  Does it mean new one is coming up?
Post by: Runway 31 on November 17, 2012, 02:09:54 PM
Kenny
Should be nearer the end of the month for the next Navdata release but if its still broken I will see about it before the end of next week
Post by: RodBearden on November 17, 2012, 03:47:00 PM
The link in reply #31 still works - use that.
Post by: dantheman on November 19, 2012, 12:57:35 PM
ANRBDBUpdater20121025 is up here
