AirNav Radar => AirNav Radar Discussion => Topic started by: jetset on June 08, 2013, 06:59:44 PM
Title: Is there a way to stop the automatic scrolling of flight info?
Post by: jetset on June 08, 2013, 06:59:44 PM
In this window here
(http://i.imgur.com/FSSvd48.jpg)
It's very frustrating when trying to find/select a particular flight and the info keeps jumping around.
Is there a way to stop it?
Title: Re: Is there a way to stop the automatic scrolling of flight info?
Post by: ACW367 on June 08, 2013, 10:17:37 PM
I think you are sorting by altitude which mean climbing/descending aircraft will jump all over the place.  Sort by registration or mode S code and it will jump around far less.
Post by: jetset on June 08, 2013, 10:26:01 PM
I'm sorting by ADS-B/Aircraft/Distance/....whatever takes my fancy.
They jump around and I can't stop them!!!!!!
Post by: RodBearden on June 09, 2013, 12:22:59 AM
Which sort order you use will affect how much rows jump around - I normally sort by Flight ID, which gives much more stability than altitude or distance, which change rapidly. Mode S or Registration will also give more stable results.
Post by: jetset on June 09, 2013, 12:24:57 AM
So there is no way of stopping/pausing it?
Post by: RodBearden on June 09, 2013, 12:37:28 AM
I don't think so - the whole point is that it's live :-)
Post by: Runway 31 on June 09, 2013, 08:14:45 AM
If you are looking for a particular flight and know its flight ID, registration or whatever you could always use the quick filter.
Flight ID = *****  or Registration = ***** or even filter by type so see for example only B788.  Just remember to press show all after your search to see everything and not just the filter.
Post by: Paulc on June 23, 2013, 12:20:57 PM
Jetset - I am the same in preferring to sort by altitude but it is incredibly frustrating just how much it jumps around. I was at Heathrow yesterday and even picking an aircraft that was on the ground did not stop it jumping around like a thing possessed.  System cannot lock onto 1 aircraft and stay locked for more than a few seconds which is very frustrating.
I know that by sorting by other info does help but if you have a lot of flights in the data line box it is very to find one that has just taken off - sorting by altitude is by far the best way to find this out rather that trying to find one that is moving.
Post by: Judwin45 on June 23, 2013, 03:00:12 PM
Just come across this thread and maybe I am being thick, but how do you change the sort sequence.
Post by: RodBearden on June 23, 2013, 03:23:46 PM
Just click the column headings - once to sort by that column, click again to reverse the sort order.
Post by: Judwin45 on June 23, 2013, 04:19:53 PM
Thanks Rod.
I always thought it was a random order that I had no control over.
Keith
