Airnav is now only picking up aircraft within 5 mile range, has anyone else had this type of fault ?
Does this mean the box is faulty or the aerial ?
Typical as go away and wanted to take the box !
Thanks for any help.
Mike.
Yes a common fault. Static causing a fault inside the box. Will need to go Walters and Stanton. Contact Airnav Support and they will give you details.
Typical !!
Thanks for your help.
Mike.
Just in case anyone suffers from this.
I sent it back for repair and the box was not faulty just the aerial, so check that before sending back.
Also if you send airnav an email you get a reply for a free repair/replacement !
This is not the case its an auto reply so beware !
Mike.
make sure you have no 2.4 ghz wireless cameras near your location ,that was the cause of my problem
