My good friend has recently bought an Airnav box and we have encountered a slight problem upon set-up. We have downloaded the most recent version and it works fine but every now and then, the signal drops out and the blue light on the box flashes on and off regularly. Unplugging the box and replugging it in even without shutting Airnav down solves the problem until next time....Any ideas as to the cause?
kind regards clive.
Try a different USB cable if you/your friend has one spare. I had the same problem and changing the cable resolved the issue.
Sounds a good suggestion as a first try to cure the issue
Sounds like a plan. Im sure he will read this and give it a try.
regards clive.
My RB sometime got this problem if I plug portable HDD to the same USB hub. I think it is USB hub power problem.
Kenny
I had problems when using a hub so stopped using it
