AirNav Radar => AirNav Radar Discussion => Topic started by: 54901 - Jim on July 28, 2015, 02:14:56 AM
Title: Antenna Deal on Amazon.com
Post by: 54901 - Jim on July 28, 2015, 02:14:56 AM
I'm going to give this antenna a try ... http://amzn.to/1Mw0Kqi ... anyone else with experience using it? Thanks!
Title: Re: Antenna Deal on Amazon.com
Post by: 73TORANA! on July 28, 2015, 09:57:24 AM
I made my own but if you do get one dont mount it like they do in the picture, I.E parallel to a pole even if its not metalic. Are you handy with a small solder iron? I can send you plans to an antenna that will leave that one for dead, not hard to make if you can do some fine work with coax and a solder iron.
Post by: 54901 - Jim on July 29, 2015, 01:20:41 AM
I did order the antenna and will use it ... for the present time ... indoors. I'm soldering iron certified and always like to learn new things, so any information you can provide would be great!  Thanks!
Post by: 73TORANA! on July 29, 2015, 04:29:12 AM
G'Day Jim,
If want to P.M me i will send you my email and then I can send you the instruction on a word doc. Its about 2 meg with pictures and is probably a bit big for here.
Cheers, Geoff.
