AirNav Radar => AirNav Radar Discussion => Topic started by: shouriken on August 25, 2015, 07:42:37 AM
Title: AirNav RadarBox ComStation
Post by: shouriken on August 25, 2015, 07:42:37 AM
Found on another forum:
(http://i1091.photobucket.com/albums/i385/josecmorales/Spotting/th_0AEC55B0-36FA-494E-8E34-DED950C51514.jpg)
(http://i1091.photobucket.com/albums/i385/josecmorales/Spotting/th_08963CB6-7AB8-45ED-92CA-5480B679F89E.jpg)
The owner seems to be from Venezuela.
Title: Re: AirNav RadarBox ComStation
Post by: AirNav Support on August 25, 2015, 11:16:27 AM
We hoped to keep this secret for longer, more details soon...
Post by: CYYZGUY on August 25, 2015, 12:08:23 PM
Just goes to show you.....You never know whats in the works behind the scenes.
Jason
Post by: CYYZGUY on August 26, 2015, 05:08:33 PM
Well, it looks fabulous and if it's the genuine article, I definitely will want one as the traffic in and around CYYZ is increasing and only 40 to 50 percent of my hits are ADS-B.  Having M-Lat on my radarbox will definitely enhance the hobby and Radarbox24 as well.
regards,
Jason
Post by: Runway 31 on August 26, 2015, 05:12:55 PM
You will need another 4 or 5 of these around To get adequate MLAT.
Post by: CYYZGUY on August 26, 2015, 05:21:49 PM
Yes, I hear you, well, there are quite a few radarbox users around CYYZ, I do have the tallest antenna if that helps..lol
Post by: tarbat on August 27, 2015, 08:12:02 AM
QuoteWe hoped to keep this secret for longer, more details soon...
Looking forward to hopefully finally getting MLAT.  What approach have you decided to take - client<>server, or client<>client.  Just curious, given all the discussions about this 3½ years ago!
(http://farm6.staticflickr.com/5694/20731564718_f97b89d140_o_d.jpg) (http://www.flickr.com/photos/tarbat/20731564718/sizes/o/)
Post by: slingshot01 on October 16, 2015, 03:56:57 PM
did anyone get the new ComStation ? if so can anyone tell me how I can see the RAW DATA from the ComStation Box directly to my computer without going on the web ?? I like the box but its useless if we cant see the data directly,, the radar box im using alredy feeds data to the web and we can view the data directly without going on the web -- if anyone knows a way around it please let us all know or I will have to trash the ComStation box cause its useless -- [email protected] -- twitter @nycbikerider
Post by: Runway 31 on October 17, 2015, 06:19:06 AM
David,
In common with the receivers provided by other trackers the comstation is intended solely to feed data to the host tracker i.e Radarbox24.  As such and in common with the other trackers receivers the data is not intended for interception.  This information has been provided to you previously and before dispatch of the unit to you.  If you have misunderstood this and wish to return the unit, return instructions have been forwarded to you by email
Post by: Aerotower on November 24, 2016, 12:31:30 AM
Any news about radarbox ComStation?
Post by: hunter2021 on December 02, 2016, 08:07:21 PM
Problems with radar antenna box
The radials of the antenna generate problem I do not have VHF and GPS
Put a 1090 filter and the reception improved a lot.
(http://i.imgur.com/4PiYGMI.jpg)
(http://i.imgur.com/gbiR2A4.png)
(http://i.imgur.com/kKgp3bB.jpg)
(http://i.imgur.com/8wYgm3F.jpg)
some help ???
Post by: neroon79 on December 03, 2016, 09:13:55 AM
From my point of fiew the antenna delivered with comstation has a design flaw. For best ADS-B (1090MHz) reception remove  the radials and the top part. That way you will lose VHF reception but ADS-B reception shall improve. GPS shall be working too, as it is received by a third receiving part integrated in the antenna.
If you apply a 1090MHz narrow band filter the frequencies of VHF (ATC: 117,975 to 137 MHz) and GPS-L1 (1575,42MHz) will be blocked and therefore no reception is possible.
By the way: Why have you blacked the Firmware version. I understand the reason for blacking Station ID/Serial number, but blacking the firmware revision doesn't make any sense, as several boxes will use the same revision.
Ingo
Post by: Runway 31 on December 03, 2016, 09:55:35 AM
The VHF requires to be set up by Airnav at their end for it to work.  However there is interference being created somewhere by the current VHF set up which is affecting ADS-B reception and as the primary purpose of the unit is for ADS-B coverage the facility is not being used on new units until a fix is found.  I would suggest removing the VHF antenna until fixed.
Post by: hunter2021 on December 03, 2016, 12:00:49 PM
 Firmware version
Radarbox 24 unit with radial and without filter does not work
(http://i.imgur.com/LNnrKTB.jpg)
Thank you for your help, but disappointed of this radarbox 24 unit for the large number of problems and have been looking for a solution
Post by: Runway 31 on December 03, 2016, 03:00:22 PM
What did support say when you contacted them, they are the only ones who can help.  If you have not already done so email [email protected] and advise them of your issue and they should be able to provide a fix and get it online.
I believe that unit should come from the factory with a filter already fitted inside and will also have an amp fitted.  I also presume you have re-booted the unit and no difference.  I would leave the radial antenna rods off.
I presume that the antenna has a clear view of the sky and you have checked all the antenna cable connections for tightness
I will also advise support of your post and get someone to contact you.
Please contact me on [email protected] with your email address.
Title: ortografia
Post by: hunter2021 on December 03, 2016, 04:03:27 PM
I already wrote to support and the only solution was to move it to another place that I tried with an antenna of the same model but the problem is still several cases in Panama, Colombia and many in Venezuela.
The only answer is that we are working on the problem but it takes time in that.
Keep waiting for a support response and I see that there is no work on weekends will be until Monday.
Thank you for your help, my friend.
Post by: Runway 31 on December 03, 2016, 05:49:12 PM
Will email them and see if I can find anything
Post by: Kenny on December 18, 2016, 07:44:05 AM
My ComStation still running firmware 20150604033550.  Does it suppose to update itself when reboot?
Couldn't find any option to check or update firmware by user.
Kenny
Quote from: hunter2021 on December 03, 2016, 12:00:49 PM
Firmware version
Post by: Runway 31 on December 18, 2016, 01:47:56 PM
Firmware cannot be updated by users
Post by: cosmefulanito on May 06, 2017, 03:03:36 AM
And how to upgrade to new firmware ?
Post by: neroon79 on May 06, 2017, 06:18:07 AM
You can't update the firmware. The Comstation is doing it by itself or the update is initiated by aurnav systems.
Ingo
