AirNav Radar => AirNav Radar Discussion => Topic started by: briand on May 26, 2016, 09:00:52 AM
Title: (windows 10
Post by: briand on May 26, 2016, 09:00:52 AM
Help
I have a new navbox and windows 10 how do I set it all up to start it running I would think the CD is out of date
sorry for being a bit thick
Brian
Title: Re: (windows 10
Post by: Runway 31 on May 26, 2016, 09:38:05 AM
Hi Brian,
Version 6 is the latest software from here http://www.airnavsystems.com/download/ANRB/ANRB60000Setup.exe download and install it.  Avoid the program files location and instil to somewhere like c:\Airnav
Once installed you will need the Windows 8 drivers from here
http://www.airnavsystems.com/download/anrb/drivers/ANRB-Win8Drivers-v2.08.30.zip
To load them in you will need to follow
. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2. Click 'Change PC Settings'.
3. Scroll down, and click 'update and recovery'
4. Click 'recovery'
5. Click under advanced start up and restart now
6. Click 'Troubleshoot'
7. Click 'Startup Settings'
8. Click Restart
9. When Win8 restarts type the number next to \"Disable driver signature enforcement\"
Instructions:
1- Download the file above;
2- Unzip it to a folder on your computer;
3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
If the above Windows prompt box does not appear:
1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
2- Point at the relevant folder and install the drivers;
You should then be good to go and start up the software.
Post by: briand on May 26, 2016, 10:07:10 AM
Thanks your your a star
Brian
Post by: Runway 31 on May 26, 2016, 10:08:00 AM
Wait till we see if you get up and running first!!
Post by: briand on May 26, 2016, 10:26:52 AM
good point but you sound like you now what your doing
Brian
Post by: briand on May 26, 2016, 06:11:45 PM
just read your answer again and ive noticed its for windows 8 will it work with windows 10 or would it be better
to go back to 8
Brian
Post by: Runway 31 on May 26, 2016, 07:24:55 PM
No, the same drivers will do OK for W10
Post by: briand on May 26, 2016, 07:34:34 PM
I promise this is the last question when I download the software should the usb cable be unplugged from the navbox
Thanks Alan
Post by: Runway 31 on May 26, 2016, 08:54:36 PM
Yes leave it unplugged until you have installed the software and the driver
Post by: briand on May 26, 2016, 09:00:46 PM
Post by: Runway 31 on May 27, 2016, 07:28:10 AM
Brian,
As peer the driver instructions in the first post
Instructions:
Post by: briand on May 27, 2016, 08:16:26 AM
Thanks again Alan
Post by: N9JIG on June 06, 2016, 12:41:47 PM
Alan:
Do you know when/if Windows 10 certified drivers will be released? In order to get it to load on Windows 10 I had to turn off Driver Signature Enforcement.
Post by: Runway 31 on June 06, 2016, 03:22:03 PM
No idea if they will get them certified.
Post by: N9JIG on June 08, 2016, 06:56:31 PM
I contacted Support and they said they are working on them. They should be available soon.
Post by: briand on June 14, 2016, 07:59:56 PM
Hi Alan
its been a while but only just received my box
I have downloaded program as per your instruction and alls well
I then altered computer settings asper instruction then downloaded the driver file and finished with
a file   ANRB-Win8Drivers-v2.08.30.zip where do I go  from here
Brian
Post by: Runway 31 on June 14, 2016, 08:07:13 PM
Brian,
1. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
4. Click 'recovery'
8. Click Restart
For Windows 8 drivers please download:
Instructions:
1- Download the file above, YOU HAVE ALREADY DONE THIS
Post by: briand on June 15, 2016, 09:18:32 AM
Morning
how do I unzip it to a folder when I click on it I get a list of things
Brian
Post by: Runway 31 on June 15, 2016, 09:35:10 AM
Create a folder and name it ANRB W8 Drivers.
Right click on the zipped folder of the W8 drivers you downloaded.  You will see on the list Extract All.
Another window will open, browse to the folder you created above the press extract and you divers will de-compress into it.
Post by: cttrondonia on June 15, 2016, 12:27:02 PM
I have a different form.
When I have installed the ANRB6.0 i have right click in the EXE, go to propriety and mark to execute in compatibility with windows 7.
After instaled, when I execute the program i have put again to execute in compatibility with windows 7.
For me have work. I use windows 10 and ANRB 6.0
Post by: briand on June 16, 2016, 01:21:25 PM
Hi Alan
still cant get nav box to work I unzip the drivers to a folder I then went into device manager clicked on
nav box a box came out saying no drivers installed clicked on update drivers  and it could not find any
when I right click on the zipped folder all I get is the driver file I downloaded shall I extract one
sorry to be a pain
Brian
Post by: Runway 31 on June 16, 2016, 03:34:29 PM
You don't go to the zipped folder, go to the unzipped one.
Follow the instructions above
Post by: briand on June 20, 2016, 12:57:26 PM
Hi Alan
all working fine thanks for your help and sorry if I was a bit of a pain
Best regards
Brian
Post by: Runway 31 on June 20, 2016, 01:22:57 PM
Just glad you got it going Brian.
