When I get a Thomson flight appear on my list, the logo is too big for the space provided and only a part of it is visable. I cleared the logo file so that it was empty and reloaded the logos. It still came back as being too large. the size of the logo in my logo file is the correct size ie 76x16. Any answers?
Thanks Malc
Malc
76x16 is the correct size for logos. The file has not got corrupted has it?
I have removed logo from file and checked other files, but Thomson logo still appears in list!
Where else can it be
Quote from: malcdee2001 on May 01, 2008, 12:39:22 PM
Are you running RadarBox 2007 or 2008 (V1.5)
V1.5 installs into a completely different directory to V1.4, so check where you are looking for the logo file. Also, I presume that you shut down and restarted RabarBox after deleting the Tompson logo?
Vi.4 and earlier is:
/AirNav Systems/AirNav RadarBox2007/Data/Logos
or for V.15
/AirNav Systems/AirNav RadarBox2008/Data/Logos
I am running v1.5 with Vista and yes I did shut down and restart the computer.
Till now I have had no problems at all.
Quote from: malcdee2001 on May 01, 2008, 04:27:24 PM
But have you checked the directories as in my last post?
Any of you guys out there with Vista might be able to help here, as I have no idea where it puts files when you install.
Yes, as I stated in my first mail, I have cleared the file and replaced. At the moment I have not got a Thomson logo (TOM) in the file, but the oversized copy still appears on the list. I have also removed any Thomson logo from the computer!
Quote from: malcdee2001 on May 01, 2008, 05:46:57 PM
If you do a Windows search for TOM.bmp, what happens?
I've got more than one TOM.bmp on my PC, the oversize SBS-1 version, and the RadarBox version. Did you ever have RadarBox V1.4 installed on your PC?
[attachment deleted by admin]
When I search for TOM.bmp it finds nothing.
I installed one of your Thomson logos but I still get the oversized version.
There is only 1 Thomson logo in the Logo file.
No, I have never had 1.4 on the computer
OK, that's me out of ideas I'm afraid. I know that Vista tucks files away in odd places, but other than that, I'm really not familiar with it.
By the way, I posted 2 TOM.bmp files - the top one (blue background) is too big for RadarBox at 60x22, it's for the SBS-1. The bottom one (white background) is the correct size for RadarBox at 76x16 - I just wanted to show you the difference.
However, I do know that RadarBox cannot display a logo if there is no associated bmp file - so you've either managed to do the impossible, or it's hiding there somewhere on your system :-)
Thanks for your help. I will keep searching and let you know when I find something.
Thanks again, Malc
Just a thought, have you taken the "hidden" status away from the virtual area oin your Vista PC as I am not sure if a search will find hidden files ? :-)
Check in the Vista virtual store - C:\Users\xxxxxxxx\AppData\Local\VirtualStore\Program Files\AirNav Systems\AirNav RadarBox 2008\
Where xxxxxxx is your windows login.
Problem solved. You guys are brilliant. Thanks
