AirNav Radar => AirNav Radar Discussion => Topic started by: oldun666 on October 14, 2016, 03:20:55 PM
Title: Photos
Post by: oldun666 on October 14, 2016, 03:20:55 PM
YIPPEE,got the photos back.
Title: Re: Photos
Post by: anorak on October 26, 2016, 04:18:32 PM
4006D6  CLJ101  G-MISG     B733  Cello Aviation  2016/10/26 17:01:50
When I clicked the link for this aircraft it came up as,
http://www.airteamimages.com/north-american-t-6-texan_SE-FUD_sweden---swedish-air-force_182806.html
I have had this happen on more than one occasion showing the same photo.
Good luck with this one, Dave.
Title: Re: Photos
Post by: Runway 31 on October 26, 2016, 05:13:46 PM
Hi Dave,
I have checked the database and there are no photos against G-MISG.  I would suggest this may have happened around the time they had issues with the photos and resulted in the wrong photo being allocated to the registration and downloaded when you picked it up and suggest that you delete the photo from your folder which is showing as G-MISG.
I have checked against lk and lk2 in the database and the only one with http://www.airteamimages.com/north-american-t-6-texan_SE-FUD_sweden---swedish-air-force_182806.html against it is SE-FUD
If you or anyone else notices similar please advise and I will check it out as if it has happened with one it has in all likely hood happened to others
Title: Re: Photos
Post by: anorak on October 26, 2016, 05:24:25 PM
As if you didn`t have enough to do.
Cheers, Alan.
Title: Re: Photos
Post by: Runway 31 on October 26, 2016, 06:56:59 PM
Cheers Dave
Title: Re: Photos
Post by: anorak on October 27, 2016, 02:56:23 PM
43C7DC  WHE06   ZZ101      EH10  AgustaWestland
comes up as;
http://planepictures.net/netsearch4.cgi?stype=reg&srng=1&srch=N192PR&offset=0&range=25
Dave.
Title: Re: Photos
Post by: Runway 31 on October 27, 2016, 05:14:56 PM
Hi Dave,
I checked the database and http://planepictures.net/netsearch4.cgi?stype=reg&srng=1&srch=N192PR&offset=0&range=25 is not showing at all, not even against the aircraft in question N192PR.  again I suggest that you delete the photo from your folder.  There are also no photos of ZZ101 on the server.  Can you search for the ph0to in your folder, I have no idea whether it will show as ZZ101 or N192PR but please advise and also if you can right click the thumbnail and then properties and tell me its created/modified dates please
Many thanks
Title: Re: Photos
Post by: anorak on October 27, 2016, 09:19:46 PM
Hi Alan, neither N192PR or ZZ101 are in the photo folder in Airnav data photo. Photo not available was showing in the photo space and the image comes up when right clicked, as was the case with the previous post.
Hope I haven`t sent you on a wild goose chase.
Dave.
Title: Re: Photos
Post by: Runway 31 on October 28, 2016, 11:52:08 AM
Thanks for the additional info Dave.  I have been right clicking on photo unavailable's as I see them but so far nothing similar.
