Hi All,
Just got my box this morning and have plugged in in at work.
Haven't played around much so far, but a couple of quick questions on the interface:
Basically, how can I change this? All I need are the main screen and the grid with flights, the altitude bit and the window where it shows photos I don't need to see, but I couldn't find an easy way to get arid of these windows?
Thanks!
Welcome to the forum!
To get rid of the aircraft photos, use Tools | Show Photos/Details
To remove the vertical display window, either use F8, or Map | Vertical Tracking Window
If you don't want to ever download or view the photos, you can also use File | Preferences | RadarBox and deselect Download Aircraft Photos.
Also, if you are using Radarbox without an Internet connection, and the menus seem slow, goto Fil | Preferences | RadarBox and deselect "Share Flight Data" - you'll have to do this each time you run Radarbox as it defaults to on for when you use the Internet.
Have fun!
The altitude box under the map screen is toggled by the F8 Key.
Under tools you will find show photo/details
On my utilities website under utilities there is a keymap file for the program, produced by Rod B.
Or if you are still having difficulty finding stuff have a look in there or the users manual.
Snap! :-)
Ahhhhh ....... it's you again :-)
Hi Steve, I'm on my "slow" internet connection at the moment, so next time you're going to beat me to the reply :-)
Cool thanks chaps, can't find tools though!
Top line upper left hand corner.
File Filters Maps Tools etc
I would have thought so as well, however mine is: File, Filters, Map, Radar Box, Window, Help.
Which version of the software are you using. 1.5 as loaded here has the 4th from the left as Tools?
Thanks, I've attached a quick screenshot from the Help menu
[attachment deleted by admin]
You are running 2007 which is v1.4
Upgrade to v1.5 which should show as Airnav Radarbox 2008
This is a more stable and all round better version, having solved a great many problems we were having.
Sorry to ask so many questions, but can you point me in the right direction of finding this?
Thanks for all your help so far, much appreciated!
Try this
http://www.airnavsystems.com/download/ANRB/ANRB15Setup.exe
Its not a problem with the help, that is why we are here and what makes this such a good product, well supported by the team at Airnav and all our fellow forum members.
Enjoy the product and come back here again soon
Steve
Awesome, have now downloaded and changed settings. Thanks again for all the help!
Anytime
