Hi guys,
Anyone have the old driver? I have tried to install the new driver, but (blue screen).
There should be no problems with the new drivers. What version of the software do you use and what version of Windows do you use.
Hi Alan,
Last version 5.00.72, and win7.
Manuel,
Exactly the same as myself. Download the drivers http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip then as they are zipped they will need to be extracted to somewhere on your computer, I would suggest hat you extract it to the drivers folder on Airnav Systems/Radarbox. Once done you will see a new folder inside the drivers folder named ANRB-Drivers-20161222.
Go to Devices and Printers/Unspecified and you will see your Radarbox. Right click on it, then click on Properties. Hardware tab/Properties. Change Settings, Driver Tab, Update driver, Browse my computer for driver software, Click Browse and click on the driver folder and you will see ANRB-Drivers-20161222, click on it and then OK and the drivers will install. Start up Radarbox and all should be OK
Manuel,
Did you get it working?
Hi Alan,
Now its working fine!
Thanks.
Best regards,
Manuel
