AirNav Radar => AirNav Radar Discussion => Topic started by: pellonet on February 02, 2019, 07:12:57 PM
Title: Range Splat
Post by: pellonet on February 02, 2019, 07:12:57 PM
Hi, I'm new here, I have been feeding to FA &  FR24 for about 3-4 years & decided to expand my system with new services & equipment. I set up RB24 on a Raspberry Pi & feed it from MM2, it has been up on the site for about 3-4 days & I'm steadily climbing up the UK charts with a busy corridor around LHR, LCY, LGW & others in the vicinity.
Just the one question for now; what does the 'range splat' indicate on my maps only I'm seeing aircraft flying through the clear areas without affecting it?
TTFN
Title: Re: Range Splat
Post by: Runway 31 on February 03, 2019, 09:32:02 AM
Hi  I presume that you mean the polar diagram per attached.  If so this is your area of coverage and the aircraft you are sending data on.
Post by: SoNic67 on February 05, 2019, 03:27:16 PM
I suppose he means that the polar diagram wasn't updated yet with his current flights. From what I see takes a few seconds to minutes to update.
I have another question. Can those "ranges" be manipulated?
I am looking at this: https://www.radarbox24.com/stations/PGANRB301046
It shows HUGE range (in the past?) but the present collection of planes in that range is severely reduced.
On FR24 I demonstrated that the "max distance" can be manipulated by just moving around a couple hundred miles the location of the radar site. Is this something similar?
This leads to artificially inflated "points".
(https://i.ibb.co/bRjfjx2/manipulation.png) (https://ibb.co/zHWkW17)
Post by: Runway 31 on February 05, 2019, 04:11:39 PM
You can always press reset to start the diagram building again
Post by: SoNic67 on February 05, 2019, 04:31:48 PM
Haha, I can't press "reset" on his map tough :)
Post by: Runway 31 on February 05, 2019, 04:36:29 PM
I can though!!
Post by: abcd567 on February 05, 2019, 11:03:20 PM
Quote from: Runway 31 on February 05, 2019, 04:11:39 PM
I could not locate reset button on map, although I am logged-in.
Can you please post some details or screenshot showing how to reach the "reset button".
Post by: Runway 31 on February 06, 2019, 08:37:13 AM
It may be just me that has it for my work with Airnav.  If you want yours reset let me know
Post by: pellonet on February 06, 2019, 05:48:29 PM
No, looks like I have it too, it's at the bottom of the 'Map Options'
Back to my original question, I know what the diagram is supposed to represent but I wanted some indication of any filtration that may have been done, as I mentioned before, I have aircraft flying through clear areas without any change to the plot even allowing time for it to catch-up.
Also, what does the colour coding in the flight list indicate?
Post by: abcd567 on February 06, 2019, 07:48:17 PM
Quote from: pellonet on February 06, 2019, 05:48:29 PM
I also have that, but that one resets map options set in that page, and NOT the range splat.
Post by: Runway 31 on February 06, 2019, 09:13:43 PM
Am not aware of any filtration but suggest you ask support pellonet.  I believe the diagram may be over a 7 day period but no idea.
Post by: abcd567 on February 06, 2019, 10:03:21 PM
BRUTE FORCE: Just keep you station off for 7 days, and range splat will reset :D
Post by: Runway 31 on February 06, 2019, 10:30:37 PM
Or easier advise me the receiver number can reset it, if thats what is wanted but I dont believe it will answer the query
Post by: vonsmalhausen on February 22, 2019, 10:55:30 AM
can this polar diagram be turned off ? i find it very anoying.
Post by: Runway 31 on February 22, 2019, 11:54:27 AM
Not that I am aware of.  It is designed to show your coverage and the aircraft you pick up only
