Flightstick 1090 (green) not being recognised by myPC
Started by colin-bmw, May 25, 2025, 08:12:55 PM
colin-bmw
Its seems like nothing works have tried the airnav drivers and Zadig nothing doing. I am in contact with support but no joy there yet.
Has anybody has issues with Windows 11 64bit set up. How did you solve issue?
#1
When you are in Zadig, do you see your stick in the window before doing the update
On Zadig when you go to Options and tick list all devices what do you see in the drop down list to the left of Edit.   You should see the stick listed as RTL2832U, highlight thestick then click install driver
colin-bmw
Did you do options/List all devices as detailed
Do you see the stick in Control Panel
Try another USB port
colin-bmw
Yes used options list all devices its not on the list either.
#5
In options/List all devices try also untick ignore Hubs or Composite parents and should show as RTL2838UHIDIR
Hows about in Control Panel
colin-bmw
Hi did untick Hubs or Composite Parents it then shown up as ADSB_1090 (COMPOSITE) so i clicked that loaded drivers and it is now working.
Thankyou so much.
