Work Around for Missing key error when installing RB24 on Bookworm and Trixie
Started by abcd567, July 12, 2025, 04:11:40 PM
On Raspberry Pi OS Bookworm, when running the RB24 installation script, sometimes one gets following error, and rbfeeder fails to install
Get:6 https://apt.rb24.com bookworm InRelease [2,431 B]
Err:6 https://apt.rb24.com bookworm InRelease
  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key 307E0F48FB61F7C75BE98B79F2A8428D3C354953, which is needed to verify signature.
Error: The repository 'https://apt.rb24.com bookworm InRelease' is not signed.
Notice: Updating from such a repository can't be done securely, and is therefore disabled by default.
Following is the workaround:
First fix the keyt error by following commands:
NOTE: Some commands, particularly the last one below are very long, and may not be fully visible. Scroll right to see and copy these in full.
sudo apt install dirmngr
sudo apt install gnupg
gpg --keyserver keyserver.ubuntu.com --recv-keys F2A8428D3C354953
gpg --export --armor F2A8428D3C354953 | sudo gpg --dearmor -o /etc/apt/keyrings/rb24.gpg
echo "deb [signed-by=/etc/apt/keyrings/rb24.gpg] https://apt.rb24.com/ bookworm main" | sudo tee /etc/apt/sources.list.d/rb24.list
After fixing rb24 key as above, run following commands to install rbfeeder:
sudo apt update
sudo apt install rbfeeder
After installation is completed, signup as follows:
After a few seconds, RBFeeder will connect to the AirNav servers and you can view your sharing-key with this command:
sudo rbfeeder --showkey
If you already have a sharing-key from a previous installation, you can set the same key using this command:
sudo rbfeeder --setkey ‹your sharing key›
And that is all. The rbfeeder installation is completed.
Che ck status by following command
To install mlat-client on RaspberryPi OS Boomworm
Issue following commands:
sudo apt install mlat-client
sudo reboot
TRIXIE
Currently (12th July 2025), the RaspberryPi OS Trixie & Debian 13 Trixie are in testing stage. The "Debian Trixie Stable" is expected to be released shortly, most likely in a month or two. Release of the Raspberry Pi OS Trixie will take another couple of months after  Debian Trixie (Stable) is released. RB24 feeder for RPi Trixie will be available couple of months after release of RaspiOS Trixie.
How to install rbfeeder on RaspberryPi OS Trixie
I have successfully installed rbfeeder's Bookworm version on Raspberry Pi OS Trixie (Testing) using the method I have described above. It runs perfectly well. No issues during installation or running. :)
How to install mlat-client on RaspberryPi OS Trixie
Issue following commands to install mlat-client on RaspberryPi OS Trixie:
wget https://github.com/abcd567a/debian13/raw/refs/heads/master/mlat-client_0.2.13_arm64.deb
sudo dpkg -i mlat-client_0.2.13_arm64.deb
My apologies in advance (old timer, unfamiliar with new tech) and unsure where to post! My Question: Albeit that I seem to be feeding to AirNav, my MLAT seems to not work! Is there a simple "recipe" to set up a Raspberry Pi  (4B) plus green USB Radar Box 1090 from scratch with all the latest feeder  files, etc?
Have a look at the rbfeeder install guide from the web page
https://www.airnavradar.com/raspberry-pi/guide
For MLAT you require to edit your exact location lat/lon on the grid on the right of your station page, what is your station bumber?
