RB with my new Vista
Started by duke, July 18, 2008, 10:18:13 PM
duke
Hi folks!
I switch my RB from my hold XP to my new Vista PC (SP1) , I install the programm, then i plug my USB cable, i open my airnav window,but the hardware is always unconnected (red square) , the blue usb light blink ( 1 blink every second)...
Somebody have a idea for my problem?
thank you very much for your help!!!!
You need to install the drivers on your Vista machine. Follow the instructions as shown on the CD case.
duke
they have a special driver for Vista? because i install the driver on Vista like a i do on my old XP PC....
Its the same driver that is on the CD. It work with Xp and Vista,
duke
I install and reinstall 20 time the driver, Window tell me, the pilot of Airnav was missing!!!????
duke
I install the driver on another Vista machine and same thing...:( The activation code is good for only one PC or many PC?
drskeptical
Hi Duke
I have just installed Vista on my PC. All you need to do is remove the driver, re start your pc and hey presto, windows detects new hardware, it then asks you to put the cd in, off it goes installs the driver and away you go.
I am sure I have seen somwhere on this forum step by step instruction on removal of drivers.
Check in Windows device manager that the RB driver appears as:
duke
i remove 10 time the drive and reinstall.... tarbat, i see this window in my manager device, put i have a yellow flag...:( :( :(
#9
duke, right click on it and select "Properties".  What does it say under "Device Status"?
Mine shows:
duke
I don't know how to show my window, but in the my device status show the drivers for this device was not installed (code 28)...
and for the driver provider is unknow
driver date is unvailable
driver version is unvailable
i have a Airnav folder in my hard disk...
I retry with my hold XP computer and he run fine, but when i try on my 2 Vista PC, its always the same thing, its like the Vista put the folder in the hard drive but don't install the driver...
When i open the AirNav window, everything is here, but i have a red square, hardware unconnected and my blue light bling on my boxe...i try the 3 USB plug on my lap top...
What i can do, replace Vista by XP?  I buy a lap top with big screen expressly for watch the aircraft and nothing work :(  i'm discouraged.
duke
They works!!!! I install my driver via Update driver box!!!! Thank you everybody!!!! YES YES!!! i'm happy!!!
