FYI my Performance issues
Started by GreekSpy2001, February 23, 2018, 03:55:10 PM
GreekSpy2001
Just an update.  I posted this in another thread
" Getting severe performance issues with my install, especially screen refreshes and reading the database explorer also getting not responding errors it I try and do anything on screen.  The monitoring  in the background seems to be working fine..  "
I believe the cause was the map I was using.  Sometime ago I took a default map changed the position a little and saved it as a map to re use.  And re used this as my default  It seems my performance issues occured whilst I was using this custom created map.  When I go back to one of the default maps my screen refresh performance is back to acceptable levels.
Also my system continually crashed.  I have found this coinsided with my Kaspersky AV software scanning the system.  I have excluded the Airnav directories from being scannned and this seems to have resloved that problem.  Will just have to do a manual scan of the excluded dirs every now and then.
Hope this is of benefit to you all.
Graham
