Update to 6.002 not found
Started by richk107, February 11, 2018, 08:48:36 PM
richk107
The link to the download page is no longer working. http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto60002.exe
Does anyone have a better link?
Rich
yang
richk107
Thanks.  This looks like the full install and not the upgrade installer.  Is there a difference since they do provide separate installer apps for full and upgrade?
Helo richl107,
Upgrade to just updates the exe some dll and sys files the rest stays untouched. The full update overwrites all customer modified files and folders too. Therefore you have to rescue and copy back your database files if you want to have them available after to full re-install.
The upgrade to is a good option to repar the install if WIN10 had to be reset due to WIN10 related issues. To have thiat option it is necessary, that ANRB is installed to a folder like  C:\airnav
If you send me your mail address via PM I'll send you a copy of upgrade to V60002.exe. File size 11,5MB
The link to the upgrade version has now been fixed
MIKE.UTD
Is this a new update, sorry if missed earlier posts and if it is what does it fix ?
Thanks.
Mike.
Its not a new update Mike, nothing changed its been out for over a year and reads as 6.00.01 when installed
Actually it reads 6.01.001 if V60002 is installed.
ShaggyPara
please need help,i had first windos 10 update which was 600.000 and not used radar box for a while, when tried today I have power light showing but no usb or signal lights flashin, done new update to 6.01.001 and also down loaded update 6.002 and installed, still no usb or signal lights flashing but radar box is showing as connected, if can help to fix this problem please call mo on07449950953 as will need talking through fault finding.
ragards
darren
In addition to the software you will need to download and unzip the driver package
http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
