connection issue
Started by mdobuk21, November 24, 2008, 06:22:57 PM
mdobuk21
hi guys
sometimes when i pull out the antenna cable from the back of the rb then put it back in lots of flights are added to myflights, then in around a minutes time they are all at timeout anybody else had this?
Cheers Mark
abrad41
Hi There
Can I ask why you are taking the antenna out of the back while RB is running.
Andy
mdobuk21
was just while i was repositioning the rb, something i came across!
Not sure what you are asking Mark, are you saying your getting all aircraft go to timeout and then it picking them up again quite often?
mdobuk21
not all aircraft go to timeout, say if i tighten or unscrew the antenna at the back of the rb for some reason more aircraft appear on the myflights coloumn then just go to timeout really weird i know!
Might just be you touching the antenna and acting as an bigger antenna temporarily :)
