Dash it...
Started by Deadcalm, January 10, 2009, 03:26:02 PM
Deadcalm
For some reason, I seem to be getting a number of targets which show a dash where I'd expect the route to be.  Is this a new feature, a problem with my installation, or have I just not noticed this before?
DC
nortonbeak
I do not have the same feature/problem on my display.
besty
Not on my screen either.
#3
DC, is the problem always on network flights, or local hardware flights as well?
I've seen this problem in the past on network flights, so I don't think it's a new problem.  I think it started when Airnav introduced the enhancement to share route data over the RB network.
Deadcalm
It doesn't seem to be confined to network flights - a fair number of live flights are affected as well...
... and I'm fairly sure I would have noticed this before.
DC
Okay, I've never seen this on local hardware flights.  Maybe worth checking your routes table for blank entries.
Deadcalm
The affected live flights aren't in the Routes table.
DC
Did these live flights appear on the network first?   If so, then the blank, erroneous routes data will have carried over from the network, which is a known bug.
gzerovti
I have just got one. RYR6671 just flying over my house now. Dash where route should be.
All other flights showing routes.
Terry
G0VTI - On the flight path to EGNM
Its network flights which don't have a route but they need to be populated in the server. Hence next time round they should have a route.
As mentioned above if there seen in local flights it cos of the network to local route bug.
Deadcalm
O.K., I won't worry too much about it then, thanks.
But in answer to tarbat, no, some of the flights were already in my live coverage area when I switched on.
DC
