Missing Airport
Started by Hamish McTorsk, February 07, 2009, 08:13:59 AM
Hamish McTorsk
I got my RB up and running yesterday and an very pleased with it, no problems at all, however, my location is EKCH which is Copenhagen and on the radar map the island of Amager upon which EKCH is located, does not exist, if you have a look at your radar maps for Copenhagen you will see what I mean, not really a problem, more of a naggy thing.
Look at the attatched pic, I have circled the Island in blue.
#1
You could create an outline for the island and put that in the Outlines folder.  It's what I use for the UK coastline, otherwise a lot of the Scottish islands are missing.  In fact, with the standard coastline, my house is in the sea!!
Other High-Res coastal outlines for UK, Ireland, Belgium, Netherlands and Northern France are available at http://www.homepages.mcb.net/bones/Kinetic/Kinetic_Utilities.htm
I've had a go at adding the island.  Just put this OUT file in your Outlines folder, and assign an appropriate colour to Map Colour Type 25.
Created using Jordons outline maker at http://www.acme.com/jef/outlines/
Hamish McTorsk
You are a star Tarbat, so ye are......Thanks a million pal
Hamish McTorsk
I have a little problem.
I have just bought a new laptop which is which is only going to be used for RB and it has vista preinstalled, I have never used vista before and I now HATE it, it is driving me round the bend, here is why......
I downloaded the file EKCH.OUT and saved it to C:\Program Files\AirNav Systems\AirNav RadarBox 2009\Outlines and the map was updated, fine.
When I try to find the file in outlines it is not there, in fact, it is not anywhere to be found on the HD....Any ideas to what has happened here, does vista hide downloaded files.
Hmmm, I think I will get rid of vista and install XP....
If possible follow the advise at http://www.airnavsystems.com/forum/index.php?topic=2051.msg16836#msg16836
Otherwise, you'll find the file in Vista's Virtual Store - C:\Users\..........\AppData\Local\VirtualStore\Program Files\AirNav Systems\AirNav RadarBox 2009\
Hamish McTorsk
