Strange extended Aircraft ID on map
Started by EGNXR, March 10, 2009, 10:31:56 AM
EGNXR
Hi all, Just noticed this strange anomily.
PH-AOD with a very extended ID tag.
Cheers John
Based in Derby 5Nm NW of EGNX
ACW367
The tags can be manually moved with a mouse click.  Therefore you may have had a stuck mouse when you hovered over the tag, which then dragged the tag around the screen as you moved the curser around the application.
EGNXR
Thank you ACW,
Every days a school day :-)
Cheers John
