Is it possible to get airport outlines for my map ?
Started by Johnn, March 08, 2009, 09:36:59 PM
Johnn
Hi, Also my map does not display the codes of the airports?
Just one more question, I lose aircraft at around 9000 ft going into Bournemouth airport (40 miles away) from my standard twig antenna, is this because my antenna is too low?
I have a external one going up on tues with a 12ft pole, is this going to help with this?, and mayby get some landings!?.
John
Johnn -
#1
Hi John
For airport codes (and names and boxes) on the map, use the menu: Map...Aviation Signs...Station Labels. There is also an Aviation Signs button on the toolbar.
The aerials are line-of-sight, so the higher the better to get a view downwards. If you can see the runway from where the aerial will be (on a clear day!), then it will see the runway too.
Hope that helps.
EDIT - in answer to your headline question, you are aware of the Outlines thread on the forum, aren't you?
