REPORT: AirNavSystems RadarBox Database -- Tail Numbers / Aircraft Info ERRORS.
Started by Brian, April 21, 2009, 05:37:03 AM
Brian
AirNavSystems RadarBox Database -- Tail Numbers / Aircraft Information ERRORS.
Please report errors you find when you are checking your aircraft database.
This will come in handy when other United States/Canada RadarBox user might be near another United States/Canada RadarBox user.
This will help to stop the spreading misinformation around on the web that comes from the AirNavSystem Radarbox Aircraft Database Server / User Email Logs.
Hope someday someone at AirNavSystems company will use this thread/topic to update the main database records, and include it in the next major software version update.
So the correct information will go out to all RadarBox users.
To double check your aircraft database.  Here are some handy links.
Gatwick Aviation Society:
http://www.gatwickaviationsociety.org.uk/modeslookup.asp
AirFrames.org
http://www.airframes.org
FAA N-Number Inquiry:
http://registry.faa.gov/aircraftinquiry/NNum_inquiry.asp
Lets keep this topic for United States/Canada Radarbox user.
Might be a good idea to start a another topic that covers the European countries RadarBox users.
Thanks.
Brian
Here is the first report from Southern California
misinformation coming from the AirNavSystem Database Server.
N241AM - Hasn't been updated over 8 months on the airNav database server. Still sending out the old aircraft information.
Others that needs to be checked out.
N100DW , N111LP , N1120Z , N1161V , N11VG
N121GV , N125BP , N19WB , N21SL , N1AR , N11T,
N26MJ , N297
N359V , N404HR , N408CS
N441A , N442MA , N457C , N495MA
N511TS , N530FX , N544PS ,
N66W , N67X
N704C , N711SE
N723R , N760
N77BT , N797WC , N8096U , N874RA
N900HA , N904CA , N90815 , N9494Z , N95BD
C-FTNB , C-GRDP
Another thread from 2007 about the database being out of date.
thread about databases being a year and a half out of date for one of their other AirNavSystem products
http://www.airnavsystems.com/forum/index.php?topic=62.0
-Brian
RadarBox User Forum
http://radarspotters.eu/forum/
We do NOT update the database ourselevs.
If we went around oursleves trying to update the database manually we would never get time for anything else. The database is constantly updating and its impossible to keep up to date.
Our database does use the GAS service to populate data.
Quote from: Brian on April 21, 2009, 05:38:20 AM
Strange, the GAS website has the same info on this aircraft as the online FAA register, what is it that the AirNav server is saying different ?
jgrloit
This problem is the Server update logic one that I asked about approx 6 months ago.
I was then suspecting the problem of being local updates not being requested, but it now looks as though the Server update logic needs modifying.
AirNav - over to you!!!!
Based in Hexham - Tyne Valley
Is it my imagination, or is this the 3rd thread that you have posted to about this issue Brian?
Geot
Dave - the problem is the frequency of re-issuance of registrations in USA and Canada, less prevalent in Europe and elsewhere. The provided DB with RB is out of date to begin with (still had AC B747s ands DC-8s that had been retired years ago and missing AC Embraers that had been inservice for a couple of years). As a consequence I had an AC DC-8 come up on my screen a few months ago which was of course another aircraft altogether. When used mobile in the USA you will get many mis-matches of biz aircraft. I keep my Aerodata Analyser running to verify the real Type for the Mode-S recognized. For NA, to stay current, we need the ability to get a refreshed DB of changes downloaded at frequent intervals, (weekly).
GeoT
Quote from: Geot on April 24, 2009, 06:27:33 PM
Regular updates of the server database would be a step in the right direction, but a more fundamental problem remains (which equally affects SBS as well as RadarBox).
That's the crazy database design decision to have no provision whatsoever for re-use of registrations and codes by different aircraft which, as you rightly say, happens all the time in countries such as the US, Germany, etc.
