Adding local markers etc in ANRB - Possible?
Started by daveg4otu, May 09, 2009, 03:37:21 PM
daveg4otu
Wondering about the possibility of adding local points within ANRB...is it possible - if So how?
For instance I would like to add  Bolt Head strip  - about 20 miles from me and  quitean active place...also some of the  local RPs around Exeter.
You can do this using outlines - I've added a few local landmarks to help me place flights.
If you aren't up to speed on outlining, I recommend my outlining notes here:  http://radarbox.gofreeserve.com/html/downloads.html
If it shows on Google Earth, then you can use Jordan's Outline maker to make your own .out file for RadarBox.  See the RadarBox Utilities website link "How to create your own outline files".
Edit: Rod, you beat me to it :-)
daveg4otu
#3
Thanks both - will have a go later.
EDIT: Tried it - works a treat!
