Nothing being tracked
Started by Jollygreen, May 22, 2009, 01:38:58 PM
Jollygreen
On several occassions today my RB has suddenly lost track of every aircraft and also the screen has frozen forcing a close and reboot. Anyone have any idea as to why this might happen
Nigel
A poor or intermittent Internet connection whilst having the Network download enabled?
What version of RB software are you using?
Jollygreen
RB2009 Software version 2.01
Has this always happend or is today the first time?
Jollygreen
It has happened before but it has happened about 4 time today. When I say nothing being tracked that also includes those flights directly overhead
Usually if all your aircraft timeout and then appear again its either a couple of reasons.
1.) Computer struggling to cope with load and hence doesn't process messages and they all timeout and the connection between your pc and RB drops and then restarts again.
2.) Your USB cable is playing up and its loosing connection or if you have an extender it not too far from the machine.
However the above should not cause your computer to freeze. This sounds like a computer fault (sometimes bad memory causes this)
Try running RB on another machine if you have one, or if you have the network on try turning it off and then running (that will reduce load).
Brimon
If it is Vista & you are running any themes or programs that enhance the theme , such as windowblinds, try disabling them.
Chasing the heavies from a secret bunker in Scotland
daveg4otu
Sounds to me like a PSU  problem , or most likely a  Graphics card /drivers problem.Just possibly a RAM/Virtualmemory problem altho I would expect an error message for this.
Overheating of  the Graphics card...or the Chipset(N Bridge) can cause freezes...check that the heatsinks are clean and that the fans where fitted are running- same time check and clean the  CPU Heatsink and fan.
Update the Graphics card drivers(get  latest set from  makers website - uninstall old before installing new).
If the freezing persists - check the PSU voltages....you can do this with Motherboard Monitor (FREE Google for it- it will also show CPU and System temps)....all voltages (12V,5V and 3.3 should be within +/- 5% of the nominal values.
Often an unstable, overloaded or failing PSU can cause freezing.
