Network Flights Slowing Down Application Response Time
Started by markyeulett, June 30, 2009, 07:24:35 PM
markyeulett
Help Please
Just subscribed to Network Flight data and have tried on 2 laptops (XP & Vista) but the load from the network flights slows the ANRB application to a virtual standstill on both.  Is this normal?  Any ideas how to speed up
If this is as good as it gets I will have to cancel the subscription as its unusable?
Mark
It shouldn't make it unusable.
How fast is your net connection? Sounds like it cannot cope with the download and hence the software is always downloading and then gets into a continuous cycle.
Quote from: markyeulett on June 30, 2009, 07:24:35 PM
Help Please
Mark
Viewing the RB network data doesn't affect the speed of the RB software unless you have a poor or intermittent Internet connection.
Why would you have to cancel the Network subscription.  It is free for the first 12 months and if you are having problems with it, you just switch it off - at no cost :-)
markyeulett
Have had box nearly 2 years - just decided to re-subscribe now that South of Spain is covered.
Just run test on broadband speed - is this too low?
Date Today 21:02
Download Speed 1091 kbps (136kB/s)
Upload Speed   327 kbps (40.9kB/s)
#4
Quote from: markyeulett on June 30, 2009, 08:04:32 PM
Date Today 21:02
So the RB Network was Ok for the first 12 months that you were using it?
If it was, then there must be something else affecting your speed.
My current connection speed is:
1.9 Mb/s down
0.36 Mb/s up
But I've run the RB Network at dial-up speeds and not had any problem.  When I did have a problem, it wasn't because the speed was slow, it was because it was inconsistent - fast one minute then slowing down to almost nothing the next.
What version of RB software are you using?
markyeulett
Did not really use it in 1st 12 months much as early software was not good with the Network - lots of conflicts.
I have a 2nd broadband connection which is :-
Date Today 21:16
Download Speed 4528 kbps (566kB/s)
Upload Speed  370 kbps (46.3kB/s)
Just swapped to this (will be calling BT about the other) and no change. Application still does not respond for long periods and hans up.  Using 2009 first full release doftware.
Mark
markyeulett
Further to the last post - the network update counter keeps freezing instead of simply counting down 29-0 and then refreshing.
Can you try the beta version on the forum and see whether that helps?
markyeulett
it freezes usually at 23 secs
is it a straight upgrade from 2009?
Quote from: markyeulett on June 30, 2009, 08:21:40 PM
All noted Mark, the Netwok has been good with all my PC's since I got RB almost 2 years ago.  The time I had trouble was using a 3G USB mobile Internet connection from Orange, laughingly called Internet Everywhere.   It should be called Internet Here and There - even in London the connection is very unreliable.  It's fine for email, but for browsing or uploading, it's pretty poor.
Shame I'm only 12 months into an 18 month contract!
markyeulett
Thanks folks - have upgraded to the beta software and it definitely seems to have improved - i will keep watch and come back if it reverts to previous performance.
Mark
Mark,
I hope that it works OK for you.  The V3.0 is beta software, so there might be the odd glitch, but let us all know how you get on :-)
markyeulett
WORKED GREAT SINCE LOADING FOR REST OF THE EVENING - CHEERS
