Network
Started by lambertw, July 12, 2009, 11:05:22 AM
itestoo
it works for instance
thank's
Laurent
Canonjohns40D
Hi Airnav for information. I am seeing Network traffic at 13.30utc on my box, however the network box at the bottom of the screen is yellow. Any thoughts?
John
Quote from: Canonjohns40D on July 12, 2009, 01:31:21 PM
John
John,
I don't think that you will be seeing network traffic if the light is yellow.  Are the aircraft moving?  Do you have preferences set to show '*' after the callsign?
You might just have the 'ghosts' of the network tracks showing after the last failure?
Canonjohns40D
Cheers you are spot on as they have all gone now just thought it was an unusual occurrence. Thanks.
John
John Racars
#19
Hi John,
Same situation with me from time to time. I think that you did not see that the light becomes "green" for a verry short while. When the light become "green" for a shortwile networkflights appears on the map. There after, when the light becomes "yellow" again all the network flights disappears after a few minutes.
Normaly, when the light is red or yellow, no networkflights can be seen.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
We are still having some problems with our RadarBox server flight data engine. We have 2 members of our team working on this problem so the server could continue to be up and down during the next 4 hours. Pls accept our apologies. We will do our best to have this sorted out asap. We will keep you informed.
John Racars
Hi Support & All,
Now it looks all is working correctly again with me. Thanks to Support for the fast solving this problem!!!
13 NM East of EHAM
ANRB:
FlyOverMe
Network downtime was only for a short while. Thanks for sorting this out Support. Great response, thankyou. <-- I meant to post this earlier.
