Alerts List gone blank
Started by mjleprix, August 01, 2009, 09:10:57 AM
mjleprix
Hi guys
This is a first for me :switched on today:had to mess around to get my usual screen up and then discovered all the alert regs I had keyued in were blank. Very inconvenient and puzzled as to what has caused this loss of memory. It has obviously feaulted to a new set up for some reason. Although Home was still present and my colour . anyone any ideas.
Mike P
Tramline
I had this happen to me first time of use.  I'd entered all the reg's and closed down the RB by using the Red X in the top right hand corner of the display - DON'T!! It will not save any changes you make, go to 'File' in top left corner and click 'Exit' - it will ask you to confirm you wish to close the application.  Click Yes and this will also SAVE your changes.
Another tip - put your alert list onto a Word Doc so you've a copy and you can cut and paste into the Alert boxes.
Hope this helps
Located 2 miles South of LHR.
mjleprix
Hi Tramline
Thanks for that. Word doc a very good idea.I'll get on to that now.
Mike
Tramline,
Total agreement with you on this one. DO NOT close down RB by using the red X at the top right hand corner as it seems to cause problems with your default map and any settings you have made but use File and Exit.
Cheers,
