SQL program recommendations?
Started by GlynH, June 06, 2009, 04:00:14 PM
John Racars
Quote from: tarbat on August 22, 2009, 03:03:41 PM
My MyLog.db3 is okay.  What's the problem?
Hi Tarbat,
I am verry sorry but with me it is not okay. I send you (and Support as well) a report in the past. So I think you (and Support) knows the problems I reported. If you read the reports I send to you careful you must see what I mean??????????????? Am I the only one in the world of ANRB-users have this problems?
I see much doubling lines of flights; flight with wrong route information, flights with NO route information while there is information in the local database....It is a big  heap of ruins when a make a querie........
I reported this to Support and they told me the problem is known and should be solved....
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Quote from: John Racars on August 22, 2009, 06:18:41 PMI see much doubling lines of flights
Yes, I get this, but usually caused by an aircraft changing it's FlightID many times.  See VT-ESO in my log from yesterday.  It correctly shows that the aircraft cycled through many Flight IDs, so not an error in my opinion.
http://www.tarbat.gofreeserve.com/data.html
Quote from: John Racars on August 22, 2009, 06:18:41 PMflight with wrong route information
Yes, sometimes the route lookup is wrong.  That's not a problem with MyLog, more a problem with the route lookup service that ANRB uses.
Quote from: John Racars on August 22, 2009, 06:18:41 PMflights with NO route information while there is information in the local database
Not seen this, but may be caused by transition from network to local flight - something Airnav have said will be investigated.
John Racars
#17
OK Tarbat, thank you for your explanation.
The crux:
Why did I not see all this phenomena in version 2? Reports I made there with the help of SQLite Maestro looks allways verry clean......
And, I have switched off the network most of the time (because I have more then enough with the receptions with my own setup).
13 NM East of EHAM
ANRB:
