Jersey flights
Started by Jeremy, September 18, 2009, 10:57:21 PM
Jeremy
There is probably a very obvious answer to this but I hear on VHF flights using 'Jersey' in their callsign but I see no Jersey airline in the database and they do not register in Myflights. Is it Jersey Airlines?
Jeremy.
G4DOQ
QRZ.com
Flybe is Jersey, We think :)
ACW367
Jersey is the callsign for FlyBE.  The reason for the callsign is that back in the 80's and 90's the airline was named Jersey European Airways.
FYI, Airframes.org's airline name search will also retrieve callsigns, so a search for JERSEY picks up FlyBE.
Jeremy
G4DOQ
QRZ.com
Jeremy
Quote from: RodBearden on September 19, 2009, 12:12:41 AM
That doesn't seem to work for me!
What Flight ID to they use?
J.
G4DOQ
QRZ.com
jgrloit
airframes.org   then select airlines in the lefthand box
Page should refresh    bottom box   enter Jersey :-
Shows:-
ICAO IATA IATA nmbr Name Callsign Country Internet Link Status From Until
JEA BE 267 British European JERSEY GB   old, renamed 2000 2002
Remarks: evolved from Jersey European in 2000, re-launched as Flybe 2002-07-18
DBJ   DUCHESS OF BRITTANY (JERSEY)
BEE BE 267 FlyBE JERSEY GB  http://www.flybe.com/ active 2002
Address: Flybe, Jack Walker House, Exeter International Airport, EX5 2HL, United Kingdom.
Remarks: formerly Jersey European Airways JEA/JY, 2000 renamed to British European Airways JEA/BE, 2002 renamed to FlyBE BEE/BE
Cert.: AOC GB-601
IAJ   ISLANDAIR JERSEY LIMITED JARLAND
   JERSEY DEVIL DUSTERS LLC  US   active
Address: 562 ONGS HAT ROAD, SOUTHHAMPTON, NJ 08088, USA.
Cert.: FAR-137 W7PG509I 1998
JEA JY 267 Jersey European Airways JERSEY GB  www.jea.co.uk (defunct) old, renamed  2000
Remarks: renamed to British European JEA/BE 2000
ALC   SOUTHERN JERSEY AIRWAYS, INC. (ATLANTIC CITY, NJ) ACOM
Based in Hexham - Tyne Valley
Jeremy - if you enter JERSEY in the Name field (circled below) it gives these results - BEE is the Flight ID.
Jeremy
G4DOQ
QRZ.com
