Flights From / To
Started by raflec, December 12, 2009, 11:27:33 AM
raflec
I am sure there is an easy solution and it is something in my settings I need to correct.
Next to the two Photographs on the main screen. In the descriptions,  I often see Flights from, but there is no way of scrolling to see were they are going to. Please could someone tell me what I need to do.
Many thanks.
Graham
Jeremy
TO is the line below FROM. Are you using the right screen reolution? see seperate thread.
J.
G4DOQ
QRZ.com
Assmuing MyFlights box to the right of map.........
Play your cursor around the left hand edge of your MyFlights box until it enables you expand/contract the width of the box then left click and slightly decrease your map width/increase the width of the box.
The bottom line of the message will appear like magic.
raflec
Thank you, Bratters.
That seems to have done the trick
Graham
