Radar Box/New Menber
Started by ashfaq1959, December 16, 2009, 12:30:04 AM
ashfaq1959
Can someone tell me if the Radar Box will work in Pakistan.Will I need an ariel. Thanks
Hi ashfaq1959.
RadarBox should work fine - it comes with an aerial that will pick up signals from about 200 miles if it has a clear, unobstructed view - position, and height, are all-important. It's very easy to set up, very portable, and will pick up most of the international airliner flights within range - there may also be local flights that it can pick up, depending on the equipment fitted to the aircraft.
Hope that helps.
Hi Ashfaq,
You have asked this before
http://www.airnavsystems.com/forum/index.php?topic=3977.msg40141#msg40141
PIA, AirBlue, Emirates, Ethiad flights will all show up.
