Opposite Directon To Destination
Started by Tailwinds, December 18, 2009, 08:02:48 PM
Tailwinds
I've just spotted this aircraft flying in what appears to be the opposite direction of his stated destination as seen on the ANRB. Seen over Detling VOR (UK), at approx 19.50 this evening heading South away from London Stanstead (EGSS). Is there something I have to do myself in the database?
Addendum....I am not on the Network. Just using my own antenna.
FDX36
N521FE MD11
FL134
KIND - EGSS
johnboy
Ive had this a few times, especially shuttle flights and Atlantic flights out of
Heathrow. I live in the centre of England so get a lot of these flights overhead.
bearcat
FDX 36 according to Flytecom routes KIND-ESSS-LFPG. To show correctly you need to edit the field in routes database ND = LFPG, and NV = EGSS
Quote from: bearcat on December 18, 2009, 08:54:54 PMFDX 36 according to Flytecom routes KIND-ESSS-LFPG. To show correctly you need to edit the field in routes database ND = LFPG, and NV = EGSS
And if a flight has more than 2 legs, as some do, you're stuffed.  :-)
Tailwinds
So I select Database Explorer, select "Routes" where it says "Select Table", along the top, then select "ND" at the bottom where it says "Field", then what?.....please.
bearcat
Select route table
seach for FDX36
highlight the ND cell and click edit or F2 and correct the entry and then enter
and then do the same for the NV cell
Tailwinds
Beware, you could find that a full time job. I have many aircraft showing incorrect routing information. It may well be due to the change from summer schedules to winter schedules and the AN route database not being upto date.
Wrong routes entirely, origin/destination information being the wrong way round, there all there.
Tailwinds
