ATC Boundaries Question
Started by flanker, November 29, 2009, 08:42:41 AM
flanker
Hi all, just a query regarding ATC boundaries within the map menu -  this option has never worked for me - nothing changes on my display whether it's checked or not? am I missing something here?
14NM SSE of EGNX
Terre
Your map color settings might be off.
You might want to check your map color settings under File > Preferences > Map Colors > ATC Boundary. Change the color for "ATC Boundary" to distinguish it from the chosen background color - eg. a strong red. Save the new color scheme before exiting the preferences window (> Export).
Fenris
Try zooming out further and see if it changes.
You can also download one of the resources files containing extended ATC boundaries and add them to your outlines folder.
flanker
Thanks for the replies guys, actually I can see them now when zooming out, actually I thought 'atc boundaries' included all the individual airport/airspace boundaries that I've seen on many screenshots but I assume they are an extra download as outline files.
14NM SSE of EGNX
Locarno1
Where can you get the individual airport/airspace boundaries that I've also seen on many screenshots? Where to download them? Like seeing controlled airspace.
