Map Zoom Setting
Started by rnsavage, January 04, 2010, 10:26:14 AM
rnsavage
Since moving to the 3.13 (been upgrading manually since 2.0), it now no longer remembers my zoom setting
This worked on all 3.0 betas, but not on 3.13
It remembers the last map file (Manchester.ml3)
However, when RB starts, the zoom setting starts showing the whole of the UK, and not the last zoom setting I had.
Any ideas
Rick
Hi Rick
Try using the Map menu...Record desktop. I'm not quite sure how wthis works, but it may tell RB to remember your map each time it closes - it's never been a problem for me, so perhaps I chose that option some time ago.
Jeremy
Windows menu - in my v.1.13.
J.
G4DOQ
QRZ.com
rnsavage
Thanks, works now and defaults to the zoom setting I had
Note for a potenial future improvement, might be to set what the Max Zoom Setting should be. For example, max zoom for me shows the whole of the UK, whereas I would prefer it to be around a 10 mile radias around Manchester Airport/Home location.
Rick
anorak
Hi Rick, when you zoom in do you use the wheel on your mouse, as I get a 0.5 mile radius on my home point?
Dave.
Dave. Exmoor, North Devon.
rnsavage
Dave, depends if I have a mouse connected to the laptop. Usually just the + button on the menu bar.
