Netwrok limit reached???
Started by Storm, February 02, 2010, 03:12:03 PM
Storm
I just got this message, I have never seen this before.
Details:
You have reached your monthly limit.
You will be able to download real-time data again on: 2010/03/05 15:00
How is this possible, being just the second day of the month?
#1
Your renewal probally didn't go through properly, email support or use the ticket system.
There is no monthly limit on RadarBox Network products but it uses the same backend for subscription as Live Flight Tracker which has limits, so this error means something went wrong in the renewal process.
Storm
Ok thanks for the reply I have sent an email.
FYI I renewed both my boxs' subscription on the same day back in October of lady year for a year's worth.
In that case are you using the same code on both, if so that might explain why its saying you are going over the limit.
Storm
I just checked they both use different codes
